[Mapserver-users] Joining geospatial data to attribute data as basis for layer
defi nition
Pryor, Clayton J
CJPRYOR at sandia.gov
Tue Oct 7 10:19:46 EDT 2003
Hi all,
I am building a prototype application in MapServer to evaluate whether we
should migrate from ArcIMS or not. One of the requirements of this
application is to render colors of geospatial data based on attributes in a
table outside of the geospatial data. In ArcIMS I defined these types of
layers as a SPATIALQUERY in the layer definition (as shown below).
<LAYER type="featureclass" name="NERC Subregions" visible="true" id="3">
<DATASET name="SDE.NERCSUBREGIONS" type="polygon"
workspace="sde_ws-24" />
<SPATIALQUERY
subfields = "LIMITEDINSIST.NERC_SUBREGION_LKUP.NERCRGN
LIMITEDINSIST.NERC_SUBREGION_LKUP.NERCSRGN
LIMITEDINSIST.EP_STATUS_BY_SUBREGION.STATUS_VALUE
LIMITEDINSIST.EP_STATUS_BY_SUBREGION.DATE_CHANGED
LIMITEDINSIST.EP_STATUS_BY_SUBREGION.DATE_VERIFIED
OBJECTID
#SHAPE#"
where="SDE.NERCSUBREGIONS.OBJECTID =
LIMITEDINSIST.NERC_SUBREGION_SPATIAL_LINK.NERC_SPATIAL_ID
and LIMITEDINSIST.NERC_SUBREGION_LKUP.NERC_SUBREGION_ID =
LIMITEDINSIST.NERC_SUBREGION_SPATIAL_LINK.NERC_SUBREGION_ID
and LIMITEDINSIST.EP_STATUS_BY_SUBREGION.NERC_SUBREGION_ID =
and LIMITEDINSIST.EP_SUBREGION_CONTACTS.NERC_SUBREGION_ID =
jointables="LIMITEDINSIST.NERC_SUBREGION_SPATIAL_LINK
LIMITEDINSIST.EP_SUBREGION_CONTACTS" />
<VALUEMAPRENDERER
lookupfield="LIMITEDINSIST.EP_STATUS_BY_SUBREGION.STATUS_VALUE">
<RANGE lower="0.0" upper="0.2" label="...">
<SIMPLEPOLYGONSYMBOL fillcolor="255,0,0"
boundarycaptype="round" boundarywidth="2"/>
</RANGE>
<RANGE lower="0.2" upper="0.4" label="...">
<SIMPLEPOLYGONSYMBOL fillcolor="255,125,0"
</RANGE>
<RANGE lower="0.4" upper="0.6" label="...">
<SIMPLEPOLYGONSYMBOL fillcolor="255,255,0"
</RANGE>
<RANGE lower="0.6" upper="0.8" label="...">
<SIMPLEPOLYGONSYMBOL fillcolor="50,50,255"
</RANGE>
<RANGE lower="0.8" upper="1.0" label="...">
<SIMPLEPOLYGONSYMBOL fillcolor="0,255,0"
</RANGE>
<OTHER label="Status not determined">
<SIMPLEPOLYGONSYMBOL fillcolor="200,200,200"
</OTHER>
<EXACT value="-99" label="Error in receipt of data">
<SIMPLEPOLYGONSYMBOL fillcolor="0,0,0" boundarycaptype="round"
boundarywidth="2"/>
</EXACT>
</VALUEMAPRENDERER>
</LAYER>
In my review of the MapServer documentation and discussions, I found a post
in 2001 that addresses the subject. In part, it reads as follows:
"No joins are supported for classification purposes. You can only use
directly attached attributes. This was done for performance reasons."
I have a few questions.
1) Is this statement still true?
2) What exactly are "directly attached attributes?" I did a search for
this term and could find nothing. I am assuming this means that the
attributes must be part of the geospatial data table.
3) How would you go about defining the equivalent to the above ArcIMS layer
definition in a MapServer application? In this question, I am concerned
about the join. I have seen examples of how to reference a singe geospatial
table and how to set up color classifications based on attribute values.
4) One thing I haven't explored is the possibility of handling the join at
the database level and then referencing the resulting join in the map
definition. Will that work?
Thanks in advance for any help.
Sincerely,
Clay
Clayton J. Pryor phone (505) 845-3557
Sandia National Laboratories
Critical Infrastructure Surety fax (505) 844-9641
PO Box 5800 MS 0451
Albuquerque NM 87185-0451 email cjpryor at sandia.gov
