[Mapserver-users] Windows NT vs. Windows 2000 / Windows XP
Menno Schepel MSchepel at gis.nl
Wed Oct 8 10:17:48 EDT 2003
Gayathri,
Thank you for your suggestion. I checked this already, but everything
seems to be OK. Since I can run mapserv QUERY_STRING=map=... from the
command prompt with good output I guess there is no problem with the dll
files. I can also run shp2img without problems. I am investigating right
now if it has something to do with ports that are blocked (firewall &
proxy). The server in question is a server that is accessible for the
public and has almost all of its ports blocked. I will let you know how
things are going,
regards,
Menno.
-----Original Message-----
To: "'MSchepel at gis.nl'" <MSchepel at gis.nl>,  mapserver-
users at lists.gis.umn.edu
Date: Wed, 8 Oct 2003 08:42:18 -0500
Subject: RE: [Mapserver-users] Windows NT vs. Windows 2000 / Windows XP
> Hi:
> There may be some missing dlls you forgot to register...
> The way to test which dlls are missing is to enter "mapserv -v" in your
> command prompt., it will
> Come up with a list of dlls that it requires., copy the same to
> "c:\windows\system32" and register...
> HTH,
> Gayathri
> From: Menno Schepel [mailto:MSchepel at gis.nl]
> Sent: Wednesday, October 08, 2003 4:15 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] Windows NT vs. Windows 2000 / Windows XP
> Hello list,
> Some days ago I posted questions about the connection of MapServer v4.0
> with an Oracle 9i database. I received some usefull tips, thanks for
> that. After some experiments something else has surfaced however. If I
> am
> testing my application using an Windows NT4 (SP6) server with IIS4
> installed everything runs smoothly. I can connect to the database and I
> am receiving a nice image of the layers within the web page. However
> when
> I use the same application on a server with either Windows 2000 Server
> or
> Windows XP Pro installed in combination with IIS5 I am getting the
> famous:
> "CGI Error
> The specified CGI application misbehaved by not returning a complete
> set
> of HTTP headers. The headers it did return are:"
> The temp files are written and look fine, but they do not show up in
> the
> web page.
> I am using the same database connection, map file, template, etc. The
> connection seems to work since the temp files are generated.
> Anyone that can share their insights about this matter or that has some
> experience with this??
> Thanks,
> Menno
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
