[Mapserver-users] MS 3.5 Tutorial
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Thu Oct 9 03:32:36 EDT 2003
IMHO you _need_ to specify the full path to your map on windows-systems!
This can be an absolute path or alternatively a relative one starting
from the cgi-directory where your mapserv.exe resides - "scripts" in
your case. MS doesn't take "wwwroot" as base-dir, the base-dir of MS to
code path from is the cgi-directory.
HTH,
Frieso ter Haseborg
- Software Development -
S&F Datentechnik GmbH&Co.KG
Reimersstr. 41b
26789 Leer, Germany
>-----Original Message-----
>From: srinivas neelapala [mailto:neelapalas at yahoo.com]
>Sent: Wednesday, October 08, 2003 10:37 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] MS 3.5 Tutorial
>Hello,
>currently i am trying to work my way through 3.5
>turorials.
>i have created a map file and am trying to get the map
>in my browser. it works when i give the full path name
>in the browser:
>1)
>http://localhost/Scripts/mapserv.exe?map=C:\Inetpub\wwwroot\IRS
\IRS3.map&mode=map
but doesn't when i try this:
2)
http://localhost/Scripts/mapserv.exe?map=/IRS/IRS3.map&mode=map
IRS is the folder that i have created in the wwwroot
directory. i am using MS 3.6 & IIS
as per the tutorials i think i needn't always specify
the full path.
Any help is appreciated
Thanks
Srini
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
