[Mapserver-users] Mapserver 4 Makefile for VC + compile probl
ems
Swaminathan, Gayathri
gayathri at ou.edu
Thu Oct 9 14:43:09 EDT 2003
Hello:
You will certainly need to compile the required libraries before you proceed
compiling mapserver.
Please find in the attachment my gd makefile, that should work for command
line compilation of GD. You will need to download the version 2+ from,
http://www.boutell.com/gd
Now here is a simple solution to compiling mapserver 4,
1) Download required libraries that is (Please find links for all these at
http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html),
a)GD Library
b)PNG library
c)Zlib
d)Regex
GD in turn needs,
a) Zlib and,
b) Freetype
(You should be able to comment out JPEG stuff in the included makefile for
GD and compile the same).
Alternatively you can compile GD easily using the MSVC++ workspace too...
As mentioned in the
http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html the following
are optional,
1) Proj.4- easy compile-clean makefile
2) GDAL - easy compile-clean makefile
3) LIBTIFF- easy compile-clean makefile
4) LIBJPEG- kind of messy
5) ArcSDE - I have not tried this option
6) EPPL7 - included with mapserver src., you will have turn on a switch for
this to get included.
Follow the instructions in mapserver docs, for compile for
commenting/uncomenting (including, excluding) options.....
Compile these libraries in your project directory first...
Download mapserver source., from here,
http://cvs.gis.umn.edu/dist/mapserver-4.0.tar.gz ( this one should not cause
any troubles..)
You probably do not want the CVS one which is a developer version., certain
things may be unstable there)...
Mapserver make is a breeze too. Just turn on the required libraries in the
nmake.opt and follow instructions in makefile.vc.
It should all work right...
Bon Appetite!
Gayathri
PS: Please do let me know if you would like for me to help in this process.,
that is FTP to a site you would mention, my compiled libraries, makefiles
etc...If yes,let me know of the FTP location, username, passwd...
-----Original Message-----
From: Stephen Clark [mailto:stephen.clark at focus.ca]
Sent: Thursday, October 09, 2003 1:28 PM
To: Swaminathan, Gayathri; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC + compile
problems
Hi
Item #1:
Does anyone have a makefile.vc for the GD-2.x version that will compile with
Visual C 6? So far I have got to the point where the mapserver compile stops
at this library.
Item #2:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerCompilation
and http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MicrosoftWindows
on the wiki site does not really explain compiling very well for mapserver
using Visual C++ Ver 6.
(Specifically the use of the nmake site)
I was wondering if someone could post their instructions.
I believe that I may be trying to compile mapserver before the other
supportin libraries are compiled. If it is correct to assume that the
supportuing libraries are to be compiled before mapserver, would someone
shed some light on their "best" solution?
thanks,
Stephen
----- Original Message -----
To: "'Stephen Clark'" <stephen.clark at focus.ca>;
<mapserver-users at lists.gis.umn.edu>
Sent: Thursday, October 09, 2003 6:21 AM
Subject: RE: [Mapserver-users] Mapserver 4 Makefile for VC
> Stephen,
> The gdal error is coming because....you have forgot/dint comment the
> following line in Makefile.vc
> "copy $(GDAL_DIR)\gdal.pdb ."
> Comment the same by including a "#" in the beginning of the line.
> On examining your nmake.opt, I see "c:\project" to be your working
> directory...Is this correct? Are all the required libraries in here?
> Have they been compiled before you proceeded to compile mapserver 4.0?
> Cheers,
> Gayathri
> Sent: Wednesday, October 08, 2003 1:32 PM
> To: mapserver-users at lists.gis.umn.edu
> I have included my makefile.vc and nmake.opt files as well as the
> compile errors foer your consideration.
> thanks,
> Stephen
> From: "Stephen Clark" <stephen.clark at focus.ca>
> To: "Swaminathan, Gayathri" <gayathri at ou.edu>; "'Yewondwossen Assefa'"
> <assefa at dmsolutions.ca>
> Cc: <mapserver-users at lists.gis.umn.edu>
> Sent: Wednesday, October 08, 2003 10:23 AM
> > Could someone post their makefile.vc and nmake.opt files.
> > I would like a version that has the minimum set of options set
> > whichI can then modify.
> > thanks
> > Stephen
> > From: "Swaminathan, Gayathri" <gayathri at ou.edu>
> > To: "'Yewondwossen Assefa'" <assefa at dmsolutions.ca>
> > Sent: Friday, September 19, 2003 8:03 AM
> > > Missed that when looking, but after careful examination saw this
> > > file.,
> > > Thanks all as always for your patience and time on this.
> > > Gayathri
> > > From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> > > Sent: Thursday, September 18, 2003 9:26 PM
> > > Cc: mapserver-users at lists.gis.umn.edu
> > > Hi There,
> > > There are now 2 files involved in the process, makefile.vc and
> > > nmake.opt where all the options are included. This separation
> > > makes things clearer and the option file can be used by sub
> > > projects like php/mapscript. All settings for necessary libraries
> > > + optional libraries are inside the nmake.opt.
> > > Later,
> > > Swaminathan, Gayathri wrote:
> > > > Hi all:
> > > > After being content with mapserver-3.6.5 for a long time now, I
> > > > was getting ready to compile mapserver 4.0 and test it.
> > > > There are several changes that I notice between mapserver-3.6.5
> > > > and mapserver-4.0. The makefile.vc in the package shrinked. I
> > > > assumed this is not the One that I should be using and proceeded
> > > > with alterations to my old makefile.vc that came from
> > > > mapserver-3.6.5
> > > > I was finally sucessful in building a mapserver with the
> > > > following enabled.
> > > > MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > > SUPPORTS=PROJ INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> > > > INPUT=SHAPEFILE
> > > > I need WMS server and WMS Client with this. I see that libcurl
> > > > is being used somehow and keep getting errors on the same.
> > > > Please, indicate to me the right corrections to makefile.vc (or)
> > > > tell me where am I going wrong in this process.
> > > > Thanks so much for your time on this.
> > > > Gayathri _______________________________________________
> > > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > Assefa Yewondwossen
> > > Software Analyst
> > > Email: assefa at dmsolutions.ca
> > > http://www.dmsolutions.ca/
> > > Phone: (613) 565-5056 (ext 14)
> > > Fax: (613) 565-0925
