[Mapserver-users] Mapserver 4 Makefile for VC + compile probl
ems
Swaminathan, Gayathri
gayathri at ou.edu
Fri Oct 10 14:52:47 EDT 2003
Agreed.
May be update the wiki for Mapserver windows Compile :)
Cheers
Gayathri
-----Original Message-----
From: Stephen Clark [mailto:stephen.clark at focus.ca]
Sent: Friday, October 10, 2003 12:52 PM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Mapserver 4 Makefile for VC + compile
problems
Brent and others,
Thanks for the effort with my compilation problems.
We should post an update to the WIKI and the DOCS for MS 4.0 and the
supporting libraries that have changes since:
http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html
was originally written.
thanks,
Stephen
----- Original Message -----
To: "Stephen Clark" <stephen.clark at focus.ca>;
<mapserver-users at lists.gis.umn.edu>
Sent: Thursday, October 09, 2003 3:43 PM
problems
> Stephen (and others who would like to compile with VC++),
> I attached instructions for building Mapserver and the dependencies
> with
> VC++. It's not THE way, just MY way. (Now that there is an excellent
> nmake.opt file with Mapserver, I'll have to update my doc to use
> it...)
> Hope it helps...
> Brent
> From: "Stephen Clark" <stephen.clark at focus.ca>
> To: "Swaminathan, Gayathri" <gayathri at ou.edu>;
> Sent: Thursday, October 09, 2003 3:19 PM
> problems
> > Hello,
> > I have commented out all the optional libraries and am just left
> > with
the
> > basic mapserver.
> > I have included the "makefile.vc" "nmake.opt" and the latest
> > compile
> error
> > listing.
> > It appears that the regex library is looking for an external library
> > "_printchar"
> > I compiled using the following steps:
> > 1. Compiled png library Version 1.2.5
> > 2. Compiled zlib library Version 1.1.4
> > 3. Compiled GD version 2.0.15
> > I removed the reference to the JPEG library because I was getting an
> > error...
> > 4. Compiled mapserver 4.0 (stable version as indicated below)
> > 5. Got the errors I am posting.
> > thanks
> > Stephen
> > From: "Swaminathan, Gayathri" <gayathri at ou.edu>
> > To: "'Stephen Clark'" <stephen.clark at focus.ca>;
> > Sent: Thursday, October 09, 2003 11:43 AM
> > Subject: RE: [Mapserver-users] Mapserver 4 Makefile for VC + compile
> > problems
> > > Hello:
> > > You will certainly need to compile the required libraries before
> > > you
> > proceed
> > > compiling mapserver.
> > > Please find in the attachment my gd makefile, that should work for
> command
> > > line compilation of GD. You will need to download the version 2+
> > > from, http://www.boutell.com/gd
> > > Now here is a simple solution to compiling mapserver 4,
> > > 1) Download required libraries that is (Please find links for all
these
> at
> > > http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html),
> > > a)GD Library
> > > b)PNG library
> > > c)Zlib
> > > d)Regex
> > > GD in turn needs,
> > > a) Zlib and,
> > > b) Freetype
> > > (You should be able to comment out JPEG stuff in the included
> > > makefile
> for
> > > GD and compile the same).
> > > Alternatively you can compile GD easily using the MSVC++ workspace
> too...
> > > As mentioned in the
> > > http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html the
> following
> > > are optional,
> > > 1) Proj.4- easy compile-clean makefile
> > > 2) GDAL - easy compile-clean makefile
> > > 3) LIBTIFF- easy compile-clean makefile
> > > 4) LIBJPEG- kind of messy
> > > 5) ArcSDE - I have not tried this option
> > > 6) EPPL7 - included with mapserver src., you will have turn on a
switch
> > for
> > > this to get included.
> > > Follow the instructions in mapserver docs, for compile for
> > > commenting/uncomenting (including, excluding) options.....
> > > Compile these libraries in your project directory first...
> > > Download mapserver source., from here,
> > > http://cvs.gis.umn.edu/dist/mapserver-4.0.tar.gz ( this one should
> > > not
> > cause
> > > any troubles..)
> > > You probably do not want the CVS one which is a developer
> > > version.,
> > certain
> > > things may be unstable there)...
> > > Mapserver make is a breeze too. Just turn on the required
> > > libraries
in
> > the
> > > nmake.opt and follow instructions in makefile.vc.
> > > It should all work right...
> > > Bon Appetite!
> > > Gayathri
> > > PS: Please do let me know if you would like for me to help in this
> > process.,
> > > that is FTP to a site you would mention, my compiled libraries,
> makefiles
> > > etc...If yes,let me know of the FTP location, username, passwd...
> > > Sent: Thursday, October 09, 2003 1:28 PM
> > > To: Swaminathan, Gayathri; mapserver-users at lists.gis.umn.edu
> > > compile problems
> > > Hi
> > > Item #1:
> > > Does anyone have a makefile.vc for the GD-2.x version that will
compile
> > with
> > > Visual C 6? So far I have got to the point where the mapserver
> > > compile
> > stops
> > > at this library.
> > > Item #2:
> > > http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerCompilation
> > > and http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MicrosoftWindows
> > > on the wiki site does not really explain compiling very well for
> mapserver
> > > using Visual C++ Ver 6.
> > > (Specifically the use of the nmake site)
> > > I was wondering if someone could post their instructions.
> > > I believe that I may be trying to compile mapserver before the
> > > other supportin libraries are compiled. If it is correct to assume
> > > that the supportuing libraries are to be compiled before
> > > mapserver, would
someone
> > > shed some light on their "best" solution?
> > > thanks,
> > > Stephen
> > > Sent: Thursday, October 09, 2003 6:21 AM
> > > > Stephen,
> > > > The gdal error is coming because....you have forgot/dint comment
> > > > the following line in Makefile.vc
> > > > "copy $(GDAL_DIR)\gdal.pdb ."
> > > > Comment the same by including a "#" in the beginning of the
> > > > line.
> > > > On examining your nmake.opt, I see "c:\project" to be your
> > > > working directory...Is this correct? Are all the required
> > > > libraries in here? Have they been compiled before you proceeded
4.0?
> > > > Cheers,
> > > > Gayathri
> > > > Sent: Wednesday, October 08, 2003 1:32 PM
> > > > I have included my makefile.vc and nmake.opt files as well as
> > > > the compile errors foer your consideration.
> > > > thanks,
> > > > Stephen
> > > > To: "Swaminathan, Gayathri" <gayathri at ou.edu>; "'Yewondwossen
Assefa'"
> > > > <assefa at dmsolutions.ca>
> > > > Cc: <mapserver-users at lists.gis.umn.edu>
> > > > Sent: Wednesday, October 08, 2003 10:23 AM
> > > > > Could someone post their makefile.vc and nmake.opt files.
> > > > > I would like a version that has the minimum set of options set
> > > > > whichI can then modify.
> > > > > thanks
> > > > > Stephen
> > > > > To: "'Yewondwossen Assefa'" <assefa at dmsolutions.ca>
> > > > > Sent: Friday, September 19, 2003 8:03 AM
> > > > > > Missed that when looking, but after careful examination saw
> > > > > > this file.,
> > > > > > Thanks all as always for your patience and time on this.
> > > > > > Gayathri
> > > > > > From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
> > > > > > Sent: Thursday, September 18, 2003 9:26 PM
> > > > > > Cc: mapserver-users at lists.gis.umn.edu
> > > > > > Hi There,
> > > > > > There are now 2 files involved in the process, makefile.vc
> > > > > > and nmake.opt where all the options are included. This
> > > > > > separation makes things clearer and the option file can be
> > > > > > used by sub projects like php/mapscript. All settings for
> > > > > > necessary
libraries
> > > > > > + optional libraries are inside the nmake.opt.
> > > > > > Later,
> > > > > > Swaminathan, Gayathri wrote:
> > > > > > > Hi all:
> > > > > > > After being content with mapserver-3.6.5 for a long time
> > > > > > > now,
I
> > > > > > > was getting ready to compile mapserver 4.0 and test it.
> > > > > > > There are several changes that I notice between
mapserver-3.6.5
> > > > > > > and mapserver-4.0. The makefile.vc in the package
> > > > > > > shrinked. I assumed this is not the One that I should be
> > > > > > > using and
proceeded
> > > > > > > with alterations to my old makefile.vc that came from
> > > > > > > mapserver-3.6.5
> > > > > > > I was finally sucessful in building a mapserver with the
> > > > > > > following enabled.
> > > > > > > MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > > > > > > SUPPORTS=PROJ INPUT=EPP L7 INPUT=POSTGIS INPUT=OGR
> > > > > > > INPUT=GDAL INPUT=SHAPEFILE
> > > > > > > I need WMS server and WMS Client with this. I see that
> > > > > > > libcurl is being used somehow and keep getting errors on
> > > > > > > the same.
> > > > > > > Please, indicate to me the right corrections to
> > > > > > > makefile.vc
(or)
> > > > > > > tell me where am I going wrong in this process.
> > > > > > > Thanks so much for your time on this.
> > > > > > > Gayathri _______________________________________________
> > > > > > > Mapserver-users mailing list
> > > > > > > Mapserver-users at lists.gis.umn.edu
> > > > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > > > > > Assefa Yewondwossen
> > > > > > Software Analyst
> > > > > > Email: assefa at dmsolutions.ca http://www.dmsolutions.ca/
> > > > > > Phone: (613) 565-5056 (ext 14)
> > > > > > Fax: (613) 565-0925
> > > > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
