[Mapserver-users] Integrating map server into my own client application - Clean HTT P Get interface
Omry Yadan omry at telmap.com
Sun Oct 12 11:28:08 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C390D5.709F0790
Content-Type: text/plain
Hello.
I would like to integrate MapServer into my own client application.
Specifically, I would like to extend my own existing map client (java based)
to support raster maps using MapServer.
What I need to know is, if there is an http interface to MapServer, which
does not leave temp maps on the disk, which I can use.
My client will keep the state, and will request maps for a specific extent
and zoom.
What I am looking for, it something like
http://omry/cgi-bin/mapserv.exe?map=/raster.map
<http://omry/cgi-bin/mapserv.exe?map=/raster.map&mode=map?img.x=32.3&img.y=3
2.4&img.width=0.5&img.height=0.5&pixels.width=400&pixels.width=400>
&mode=map?img.x=32.3&img.y=32.4&img.width=0.5&img.height=0.5&pixels.width=40
0&pixels.width=400
Or in human language:
I need to specify the map x, y width and height, and also the resulting
image pixels size.
Anyone?
Content-Type: text/html
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C390E7.245D1130">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
span.GramE
	{mso-style-name:"";
	mso-gram-e:yes;}
@page Section1
	{size:612.0pt 792.0pt;
	margin:72.0pt 90.0pt 72.0pt 90.0pt;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin:0cm;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hello.<o:p></o:p></span></font></p>
font-family:Arial'>I would like to integrate <span =
class=3DSpellE>MapServer</span>
into my own client application.<o:p></o:p></span></font></p>
font-family:Arial'>Specifically, I would like to extend my own existing =
map
client (java based) to support raster maps using <span =
class=3DSpellE>MapServer</span>.<o:p></o:p></span></font></p>
font-family:Arial'>What I need to know is, if there is an http =
interface to <span
class=3DSpellE>MapServer</span>, which does not leave temp maps on the =
disk, which
I can use.<o:p></o:p></span></font></p>
font-family:Arial'>My client will keep the state, and will request maps =
for a
specific extent and zoom.<o:p></o:p></span></font></p>
font-family:Arial'>What I am looking for, it something like =
font-family:Arial'><a
href=3D"http://omry/cgi-bin/mapserv.exe?map=3D/raster.map&amp;mode=3Dmap=
?img.x=3D32.3&amp;img.y=3D32.4&amp;img.width=3D0.5&amp;img.height=3D0.5&=
amp;pixels.width=3D400&amp;pixels.width=3D400">http://omry/cgi-bin/mapse=
rv.exe?map=3D/raster.map&amp;mode=3Dmap?img.x=3D32.3&amp;img.y=3D32.4&am=
p;img.width=3D0.5&amp;img.height=3D0.5&amp;pixels.width=3D400&amp;pixels=
.width=3D400</a><o:p></o:p></span></font></p>
font-family:Arial'><o:p>&nbsp;</o:p></span></font></p>
font-family:Arial'>Or in human language:<o:p></o:p></span></font></p>
font-family:Arial'>I need to specify the map x, y width and height, and =
also
the resulting image pixels size.<o:p></o:p></span></font></p>
font-family:Arial'>Anyone?<o:p></o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C390D5.709F0790--
