[Mapserver-users] ECW Example
Omry Yadan
omry at telmap.com
Sun Oct 12 11:38:35 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C390D6.E5E02920
Content-Type: text/plain
1. Can someone send me an example for a map file for ECW?
2. What would you recommend as a format for large raster map With
tiles?
Content-Type: text/html
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C390E8.99DA2A50">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:1398016860;
mso-list-type:hybrid;
mso-list-template-ids:2135987258 67698703 67698713 67698715 67698703 =
67698713 67698715 67698703 67698713 67698715;}
@list l0:level1
{mso-level-tab-stop:36.0pt;
mso-level-number-position:left;
text-indent:-18.0pt;}
ol
{margin-bottom:0cm;}
ul
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<ol style=3D'mso-margin-top-alt:0cm' start=3D1 type=3D1>
<li class=3DMsoNormal style=3D'mso-list:l0 level1 lfo1;tab-stops:list =
36.0pt'><font
size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;font-family:Arial'>Can
someone send me an example for a map file for =
ECW?<o:p></o:p></span></font></li>
36.0pt'><font
style=3D'font-size:10.0pt;font-family:Arial'>What
would you recommend as a format for large raster map <span =
class=3DGramE>With</span>
tiles? <o:p></o:p></span></font></li>
</ol>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
font-family:Arial'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C390D6.E5E02920--
