[Mapserver-users] Integrating map server into my own client application - Clean HTT P Get interface
Ed McNierney
ed at topozone.com
Sun Oct 12 11:59:28 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C390D9.D0E2B0DC
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Omry -
=20
You just did just what you want!
=20
If you make a MapServer request and use the "mode=3Dmap" command, the
generated map image is streamed directly to the client and no temp files
are involved.
=20
The WMS interface does the same thing.
=20
- Ed
=20
Ed McNierney
President and Chief Mapmaker
TopoZone.com
=20
-----Original Message-----
Sent: Sunday, October 12, 2003 11:28 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Integrating map server into my own client
=20
Hello.
I would like to integrate MapServer into my own client application.
Specifically, I would like to extend my own existing map client (java
based) to support raster maps using MapServer.
What I need to know is, if there is an http interface to MapServer,
which does not leave temp maps on the disk, which I can use.
My client will keep the state, and will request maps for a specific
extent and zoom.
What I am looking for, it something like=20
http://omry/cgi-bin/mapserv.exe?map=3D/raster.map&mode=3Dmap?img.x=3D32.3=
&img.
y=3D32.4&img.width=3D0.5&img.height=3D0.5&pixels.width=3D400&pixels.width=
=3D400
=20
Or in human language:
I need to specify the map x, y width and height, and also the resulting
image pixels size.
=20
Anyone?
Content-Type: text/html;
charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C390B8.461B6AD0">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"time"/>
<o:SmartTagType =
name=3D"date"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Wingdings;
panose-1:5 0 0 0 0 0 0 0 0 0;
mso-font-charset:2;
mso-generic-font-family:auto;
mso-font-pitch:variable;
mso-font-signature:0 268435456 0 0 -2147483648 0;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoPlainText, li.MsoPlainText, div.MsoPlainText
{margin:0in;
font-size:10.0pt;
font-family:"Courier New";
span.EmailStyle17
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle18
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:2070954789;
mso-list-type:hybrid;
mso-list-template-ids:1326641186 1357549130 67698691 67698693 67698689 =
67698691 67698693 67698689 67698691 67698693;}
@list l0:level1
{mso-level-start-at:0;
mso-level-number-format:bullet;
mso-level-text:-;
mso-level-tab-stop:.75in;
mso-level-number-position:left;
margin-left:.75in;
text-indent:-.25in;
font-family:Arial;
ol
{margin-bottom:0in;}
ul
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><span class=3DSpellE><font size=3D2 color=3Dnavy =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>Omry</span></font=
></span><font
size=3D2 color=3Dnavy face=3DArial><span =
color:navy'> –<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>You just did just what you =
want!<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>If you make a <span =
class=3DSpellE>MapServer</span>
request and use the “mode=3Dmap” command, the generated map =
image is
streamed directly to the client and no temp files are =
involved.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>The WMS interface does the same =
thing.<o:p></o:p></span></font></p>
style=3D'font-size:
<p class=3DMsoNormal =
style=3D'margin-left:.75in;text-indent:-.25in;mso-list:l0 level1 lfo1;
tab-stops:list .75in'><![if !supportLists]><font size=3D2 color=3Dnavy =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;mso-fareast-font-family:Arial=
color:navy'><span style=3D'mso-list:Ignore'>-<font size=3D1 =
face=3D"Times New Roman"><span
style=3D'font:7.0pt "Times New =
Roman"'>
</span></font></span></span></font><![endif]><font size=3D2 color=3Dnavy
style=3D'font-size:10.0pt;font-family:Arial;color:navy'>Ed<o:p></o:p></sp=
an></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Ed =
McNierney<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>President and Chief =
Mapmaker<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>TopoZone.com<o:p></o:p></span></font=
></p>
style=3D'font-size:
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'>-----Original =
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> Omry Yadan
[mailto:omry at telmap.com<span class=3DGramE>] <br>
<b><span style=3D'font-weight:bold'>Sent</span></b></span><b><span
style=3D'font-weight:bold'>:</span></b> </span></font><st1:date =
Month=3D"10"
Day=3D"12" Year=3D"2003"><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>Sunday, October 12, =
2003</span></font></st1:date><font
style=3D'font-size:10.0pt;font-family:Tahoma'> </span></font><st1:time
Hour=3D"11" Minute=3D"28"><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>11:28 AM</span></font></st1:time><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'><br>
<b><span style=3D'font-weight:bold'>To:</span></b>
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
[Mapserver-users]
interface</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:.5in'><font size=3D3 =
style=3D'font-size:12.0pt'><o:p> </o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Hello.<o:p></o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>I would like to integrate =
into my own client application.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Specifically, I would like =
to extend
my own existing map client (java based) to support raster maps using =
MapServer.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>What I need to know is, if =
there is
an http interface to MapServer, which does not leave temp maps on the =
disk,
which I can use.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>My client will keep the =
state, and
will request maps for a specific extent and =
zoom.<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>What I am looking for, it =
something
like <o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><a
href=3D"http://omry/cgi-bin/mapserv.exe?map=3D/raster.map&mode=3Dmap?=
img.x=3D32.3&img.y=3D32.4&img.width=3D0.5&img.height=3D0.5&am=
p;pixels.width=3D400&pixels.width=3D400">http://omry/cgi-bin/mapserv.=
exe?map=3D/raster.map&mode=3Dmap?img.x=3D32.3&img.y=3D32.4&im=
g.width=3D0.5&img.height=3D0.5&pixels.width=3D400&pixels.widt=
h=3D400</a><o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Or in human =
language:<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>I need to specify the map =
x, y width
and height, and also the resulting image pixels =
size.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Anyone?<o:p></o:p></span></f=
ont></p>
</div>
</body>
</html>
=00
------_=_NextPart_001_01C390D9.D0E2B0DC--
