[Mapserver-users] PDF output
Marco Sbrana
sbrana at casaccia.enea.it
Mon Oct 13 03:52:31 EDT 2003
I'm working with Mapserver ver.4.00 on a NT4 sp6 server.
I have a problem with PDF format: when i call my map file i have back a file
in text format.
I think that is a problem with MIMETYPE setting, i verify on the webserver
and all is OK (i can read fine other pdf format files).
When i use a template file i find the pdf file in tmp directory and i can
see it correctly.
Where is the problem? Anybody can help me
My map file:
NAME S1EX2
EXTENT -97.238976 41.619778 -82.122902 49.38562
SIZE 400 300
SHAPEPATH "d:\serverweb\tutorial35\data"
IMAGETYPE pdf
OUTPUTFORMAT
NAME pdf
MIMETYPE "application/x-pdf"
DRIVER pdf
EXTENSION "pdf"
END
LAYER # States
NAME "states"
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
CLASSITEM "STATE"
CLASS # Michigan class
NAME "Michigan"
EXPRESSION "Michigan"
COLOR 0 0 128
OUTLINECOLOR 0 0 0
END # end of Michigan class object
CLASS # Minnesota class
NAME "Minnesota"
EXPRESSION "Minnesota"
COLOR 255 255 0
OUTLINECOLOR 0 0 0
END # end of Minnesota class object
CLASS # Wisconsin class
NAME "Wisconsin"
EXPRESSION "Wisconsin"
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END # end of Wisconsin class object
END # end of layer object
END # end of map file
