[Mapserver-users] GDAL utilities (openv 1.6) and ECW.
Omry Yadan
omry at telmap.com
Tue Oct 14 03:49:29 EDT 2003
I have downloaded 'openev 1.60' binaries for windows, I didn't compile it
myself..
Do you know if binaries that supports ECW are available?
-----Original Message-----
From: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Sent: × 13 ××ק×××ר 2003 19:10
To: 'Omry Yadan'; bartvde at xs4all.nl
Cc: mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] ECW Example
Hi:
Is your gdal compiled with the ECW_SDK from ermapper's site...
You will have to make changes to the nmake.opt of gdal to implement this..
Cheers,
Gayathri
Sent: Monday, October 13, 2003 10:46 AM
To: bartvde at xs4all.nl
No luck..
[c:\projects\ecw]gdalinfo sf5504.ecw
ERROR 4: `sf5504.ecw' not recognised as a supported file format.
GDALOpen failed - 4
From: bartvde at xs4all.nl [mailto:bartvde at xs4all.nl]
Sent: × 13 ××ק×××ר 2003 13:46
To: Omry Yadan
Hi Omry,
can you always cc the mailing list please?
You can use gdalinfo.exe for this.
See:
http://gdal.maptools.org/gdal_utilities.html
Best regards,
Bart
> Hi Bart,
> How do I find the correct extent for my sample ECW file?
> From: Bart van den Eijnden [mailto:bartvde at xs4all.nl]
> Sent: à 12 à å÷èåáø 2003 18:06
> To: Omry Yadan; mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] ECW Example
> Hi,
> attached an example map file which uses ECW files.
> I think ECW is generally a good format to use, but also depending on
> your color depth (ECW is always 24-bit). I did not find any big
> performance improvement using tiles for my specific situation in which
> the largest ECW file was 5 Gb.
> Best regards,
> Bart
> # Start of map file
> NAME GEOSTREETS
> STATUS ON
> SIZE 600 600
> #EXTENT 388107.634400379 5203120.88405952 500896.339019834
> 5310243.30613897 EXTENT 150000 300000 260000 630000
> UNITS METERS
> IMAGECOLOR 255 255 255
> # Start of web interface definition (including WMS enabling metadata)
> # WEB
> HEADER demo_header.html
> TEMPLATE demo.html
> FOOTER demo_footer.html
> MINSCALE 50
> MAXSCALE 155000000000
> IMAGEPATH "set in demo_init.html"
> IMAGEURL "set in demo_init.html"
> METADATA
> WMS_TITLE "UMN MapServer Geostreets"
> WMS_ABSTRACT "UMN MapServer Geostreets"
> WMS_ACCESSCONSTRAINTS none
> WMS_ONLINERESOURCE "http://localhost:8081/bart/demo_init.html"
> WMS_SRS "EPSG:28992"
> END
> END
> # Start of layer definitions
> LAYER
> NAME "layer_1"
> TILEINDEX "E:\bart\ecw\geostreets.shp"
> TILEITEM "location"
> #DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level1.ecw"
> TYPE RASTER
> MINSCALE 0
> MAXSCALE 12000
> STATUS ON
> DUMP TRUE
> METADATA
> WMS_TITLE "Geostreets Level 1"
> WMS_ABSTRACT "Geostreets Level 1"
> END
> END
> LAYER
> NAME "layer_2"
> DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level2.ecw"
> TYPE RASTER
> MINSCALE 12000
> MAXSCALE 25000
> STATUS ON
> DUMP TRUE
> METADATA
> WMS_TITLE "Geostreets Level 2"
> WMS_ABSTRACT "Geostreets Level 2"
> END
> END
> LAYER
> NAME "layer_3"
> DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level3.ecw"
> TYPE RASTER
> MINSCALE 35000
> MAXSCALE 100000
> STATUS ON
> DUMP TRUE
> METADATA
> WMS_TITLE "Geostreets Level 3"
> WMS_ABSTRACT "Geostreets Level 3"
> END
> END
> LAYER
> NAME "layer_4"
> DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level4.ecw"
> TYPE RASTER
> MINSCALE 100000
> MAXSCALE 250000
> STATUS ON
> DUMP TRUE
> METADATA
> WMS_TITLE "Geostreets Level 4"
> WMS_ABSTRACT "Geostreets Level 4"
> END
> END
> LAYER
> NAME "layer_5"
> DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level5.ecw"
> T
> YPE RASTER
> MINSCALE 250000
> MAXSCALE 1000000
> STATUS ON
> DUMP TRUE
> METADATA
> WMS_TITLE "Geostreets Level 5"
> WMS_ABSTRACT "Geostreets Level 5"
> END
> END
> LAYER
> NAME "layer_6"
> DATA "E:\klicnet\data\webstreets\Gstreets_2003\ecw\level6.ecw"
> TYPE RASTER
> MINSCALE 1000000
> MAXSCALE 15000000
> STATUS ON
> DUMP TRUE
> METADATA
> WMS_TITLE "Geostreets Level 6"
> WMS_ABSTRACT "Geostreets Level 6"
> END
> END
> END # Map File
> On Sun, 12 Oct 2003 17:38:35 +0200, Omry Yadan <omry at telmap.com>
> wrote:
>> 1. Can someone send me an example for a map file for ECW?
>> 2. What would you recommend as a format for large raster map With
>> tiles?
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
