[Mapserver-users] need help in creating a mapfile
Björn Platzen
bplatzen at sosnetz.de
Tue Oct 14 06:34:43 EDT 2003
Hi Murat,
Does ArcExplorer show you any coordinates eg. when you drive with your
mouse over a map? The upper left and the lower right edge should be
your extend.
But I think, if you don's specify an extend, Mapserver will calculate it
for you...
Bye,
Bjoern.
PS: A small tool to show shapefiles and get some information out of it
(if you work with Windoze) is Blue Marbles Geographic Explorer wich can
be downloaded here:
http://www.bluemarblegeo.com/products/geoexplorer.php
PS2:You should always send a copy of your message to the mailinglist 8~)
Am Dienstag, 14. Oktober 2003 10:12 schrieb Murat Iþýk:
> Thanks alot for answering:)
> What I do is: I take the demo.map, I turn off the default layer
> LAYER
> NAME ctybdpy2
> TYPE POLYGON
> STATUS DEFAULT
> DATA ctybdpy2
> by putting # in front of all the lines belonging to this layer. Then
> I go to layer named mcd90py2 and rename the two "mcd90py2" as
> ERENKOY_ORNEKMAHALLE_PG_region, which one of my 20 diffirent layers.
> I have copied all 3 files of ERENKOY_ORNEKMAHALLE_PG_region into
> "data" folder. I dont change anything else.
> And I get an empty map. I dont get an error. I tried this both with
> and without the # in front of the TEMPLATE "mcd90py2.html", HEADER
> "mcd90py2_header.html", FOOTER "mcd90py2_footer.html" lines hoping it
> will do any help.
> If I am to change ExTEND how do I learn the extend of my files. As
> for helping utility I only have ArcExplorer with which I have not
> become fully familiar with.
> Thanks alot:)
small office solutions
info at sosnetz.de - http://www.sosnetz.de
