[Mapserver-users] no image(s)
Michael Smith msmith at sanangelompo.org
Tue Oct 14 11:52:53 EDT 2003
The EXTENT in your mapfile should match your shapefile extents if that is
the area you are wanting to view.  If you know the coordinates and units for
your area you should be able to verify if the mapfile or your shapefile is
using the correct coordinates for your area.
Should be:
EXTENT [min x] [min y] [max x] [max y]
I would not worry about querying data at this point.  Lets get the mapserver
to display a map first.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of ronny
Sent: Tuesday, October 14, 2003 3:43 AM
To: Michael Smith
Cc: MapsHelp
Subject: RE: [Mapserver-users] no image(s)
i downloaded the shapechck software and viewed the
shapefile with it..below is what am getting :
Xmin: 35.786953
Ymin: -0.721388
Xmax: 36.408545
Ymax: 0.094966
Zmin: 0
Zmax: 0
Mmin: 0
Mmax: 0
from the look of it am really confused,,i don't know
all what it means,,as in what to put where and how!! i
now feel like i could scream :)
--- Michael Smith <msmith at sanangelompo.org> wrote:
> Ronny,
> I had the same problem with mapserver when I first
> began.  I became VERY
> frustrated.  The good news is that your server seems
> to be up and running
> correctly as you are not getting any errors you just
> can see your maps.  The
> problem I would guess lies within your
> extents/units.  The way I solved the
> problem was that I found a mapserver user located in
> the same state as me
> and got a copy if his map file.  Once I loaded his
> mapfile, I simply
> inserted my shapefile (though in a different area of
> the state) in his
> working mapfile and initiated mapserver.  I could
> see his city and began
> zooming out and presto I could see my maps.
> If this will not work for you, another suggestion
> would be to download a
> file off the net called shapechk.exe (or something
> like that... you can do a
> search).  Run the program on your shapefile and it
> will give you the correct
> extents for your shapefile.  Hope this helps.
> From: mapserver-users-admin at lists.gis.umn.edu
> Behalf Of ronny
> Sent: Friday, October 10, 2003 4:55 AM
> To: Till Adams
> Cc: MapsHelp
> Subject: Re: [Mapserver-users] no image(s)
> yes, thanks,i have even tried reducing/increasing
> the
> extent but still the problems pursists..no errors or
> something to indicate what is wrong,,just cann't
> display no image
> --- Till Adams <adams at terrestris.de> wrote:
> > Dear Ronny,
> > does your extent fit to the extent (BoundignBox)
> of
> > your data?
> > Cheers,
> > Till
> > ronny schrieb:
> > > am a newbie, when i try to load map am getting
> > blank
> > > image! everything else is ok ..i sincerely don't
> > know
> > > what am doing wrong and am stuck and very
> > > desperate..my mapfile is as follows:
> > > # Start of map file
> > > NAME TEST
> > > STATUS ON
> > > SIZE 600 600
> > > EXTENT 388107.634400379 5203120.88405952
> > > 500896.339019834 5310243.30613897
> > > UNITS METERS
> > > SHAPEPATH "data"
> > > IMAGECOLOR 255 255 255
> > > WEB
> > >   HEADER test_header.html
> > >   TEMPLATE test.html
> > >   FOOTER test_footer.html
> > >   MINSCALE 1000
> > >   MAXSCALE 1550000
> > >   IMAGEPATH "set in test.html"
> > >   IMAGEURL "set in test.html"
> > >   METADATA
> > >     WMS_TITLE "scomMapserver"
> > >     WMS_ACCESSCONSTRAINTS none
> > >     WMS_ONLINERESOURCE
> > > "http://var/www/html/mapsite/test.html"
> > >     WMS_SRS "EPSG:26915"
> > >   END
> > > END
> > > QUERYMAP
> > >   SIZE 200 200
> > >   STATUS ON
> > >   STYLE HILITE
> > >   COLOR 255 0 0
> > > END
> > > # Start of reference map
> > > #REFERENCE
> > > #  IMAGE graphics/ref.png
> > > #  EXTENT 393234.393701263 5205405.16440722
> > > 495769.579718949 5307959.02579127
> > > #  SIZE 50 50
> > > #  STATUS ON
> > > #  COLOR -1 -1 -1
> > > #  OUTLINECOLOR 255 0 0
> > > #END
> > > # Start of legend
> > > LEGEND
> > >   KEYSIZE 18 12
> > >   LABEL
> > >     TYPE BITMAP
> > >     SIZE MEDIUM
> > >     COLOR 0 0 89
> > >   END
> > >   STATUS ON
> > > END
> > > # Start of scalebar
> > > SCALEBAR
> > >   LABEL
> > >     COLOR 255 255 255
> > >     SIZE tiny
> > >   END
> > >   STYLE 1
> > >   SIZE 80 2
> > >   COLOR 255 255 255
> > >   UNITS MILES
> > >   INTERVALS 1
> > >   TRANSPARENT TRUE
> > >   STATUS TRUE
> > > END
> > > # Start of symbol definitions (we're only using
> a
> > few)
> > > SYMBOL
> > >   NAME 'circle'
> > >   TYPE ELLIPSE
> > >   POINTS 1 1 END
> > >   FILLED TRUE
> > > END
> > > # Start of layer definitions
> > > LAYER
> > >  NAME test_region
> > >   TYPE RASTER
> > >   STATUS DEFAULT
> > >   DATA "test_region"
> > >   CLASSITEM 'cty_name'
> > >   CLASS
> > >     EXPRESSION 'Test'
> > >      OUTLINECOLOR 128 128 128
> > >     COLOR 225 225 185
> > >   END
> > >   CLASS #
> > >     EXPRESSION /./
> > >     COLOR 255 255 255
> > >   END
> > >   END
> > > LAYER
> > >   NAME Towns_point
> > >   GROUP cities
> > >   TYPE RASTER
> > >   DATA "Towns_point"
> > >   STATUS OFF
> > >   CLASSITEM 'city_name'
> > >   CLASS
> > >     NAME "Cities & Towns"
> > >     EXPRESSION NONE
> > >     COLOR 255 225 90
> > >     TEMPLATE "population.html"
> > >   END
> > >   HEADER "population_header.html"
> > >   FOOTER "population_footer.html"
> > >   DUMP TRUE # allow GML export
> > >   END
> > > END
> > > LAYER
=== message truncated ===
ronny
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
