R: [Mapserver-users] PDF output
Marco Sbrana
sbrana at casaccia.enea.it
Wed Oct 15 02:53:44 EDT 2003
I try with two scenery:
1) I just use:
<A
href="/scripts/mapserv.exe?map=d:\serverweb\tutorial35\s1\s1ex2.map&mode=map
file pdf</A> to call a map file.
Web server ask me to download the file and the answer is:
%PDF-1.3 %äãÏÒ 5 0 obj........................
a classic MIMETYPE problem, I think.
2) I try using a map file that uses a template, Mapserver answer with: CGI
Error
The specified CGI application misbehaved by not returning a complete set of
HTTP headers. The headers it did return are: but in TMP directory I find
the pdf file created correctly
-----Messaggio originale-----
Da: Stephen Clark [mailto:stephen.clark at focus.ca]
Inviato: martedì 14 ottobre 2003 18.57
A: Marco Sbrana; mapserver-users at lists.gis.umn.edu
Oggetto: Re: [Mapserver-users] PDF output
Marco,
I am working on PDF output using a similar system . MS 4.00 on Win2k using
Apache 2.0.47.
Post your template file. That may be helpful in finding the problem
Stephen
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Monday, October 13, 2003 12:52 AM
Subject: [Mapserver-users] PDF output
> I'm working with Mapserver ver.4.00 on a NT4 sp6 server.
> I have a problem with PDF format: when i call my map file i have back a
file
> in text format.
> I think that is a problem with MIMETYPE setting, i verify on the webserver
> and all is OK (i can read fine other pdf format files).
> When i use a template file i find the pdf file in tmp directory and i can
> see it correctly.
> Where is the problem? Anybody can help me
> My map file:
> NAME S1EX2
> EXTENT -97.238976 41.619778 -82.122902 49.38562
> SIZE 400 300
> SHAPEPATH "d:\serverweb\tutorial35\data"
> IMAGETYPE pdf
> OUTPUTFORMAT
> NAME pdf
> MIMETYPE "application/x-pdf"
> DRIVER pdf
> EXTENSION "pdf"
> END
> LAYER # States
> NAME "states"
> DATA states_ugl
> STATUS DEFAULT
> TYPE POLYGON
> CLASSITEM "STATE"
> CLASS # Michigan class
> NAME "Michigan"
> EXPRESSION "Michigan"
> COLOR 0 0 128
> OUTLINECOLOR 0 0 0
> END # end of Michigan class object
> CLASS # Minnesota class
> NAME "Minnesota"
> EXPRESSION "Minnesota"
> COLOR 255 255 0
> OUTLINECOLOR 0 0 0
> END # end of Minnesota class object
> CLASS # Wisconsin class
> NAME "Wisconsin"
> EXPRESSION "Wisconsin"
> COLOR 255 0 0
> OUTLINECOLOR 0 0 0
> END # end of Wisconsin class object
> END # end of layer object
> END # end of map file
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
