[Mapserver-users] setExpression difficulty
Lowell Filak
lfilak at medinaco.org
Wed Oct 15 09:02:45 EDT 2003
Have you already tried '$tempClass->setExpression("\"$key\"");' ?
Lowell
The following message was sent by Nick Petersen-Bergeron
<bergeron at zedxinc.com> on Tue, 14 Oct 2003 14:16:06 -0400.
> I'm trying to dynamically create classes in a layer using Perl
mapscript 3.6.
> Here's my code:
> foreach $key (sort keys %colors) {
> my $tempClass = new classObj($soilLayer);
> $tempClass->setExpression("$key");
> $tempClass->{name} = $key;
> $tempClass->{size}=5;
> my $r = $colors{$key}{'R'};my $g = $colors{$key}{'G'};my
> $b = $colors{$key}{'B'};
> my $rgb = 0;
> foreach $clr ($r,$g,$b) {
> $rgb <<=8;
> $rgb += $clr;
> warn "$rgb\n";
> $tempClass->{color} = $rgb;
> $key is essentially the datum that I am looking to assign the different
> shapes to different classes by. It is set up as the classitem in the
> layer. Now, the problem is that when I try and use setExpression, I get
> the following error:
> getSymbol(): Symbol definition error. (083028):(237)
> The first number(083028) is the piece of datum I'm passing in, $key. The
> second is the last non-end line of the mapfile. Any ideas?
> System Administrator
> ZedX Inc.
> 369 Rolling Ridge Drive
> Bellefonte, PA. 16823
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
