[Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and PIXMAP symbols, text-label colors no longer work correctly.
Martin, Daniel A
Daniel.A.Martin at erac.com
Wed Oct 15 13:29:45 EDT 2003
Yes, I am using antialiasing. Though, it worked fine with 3.6. I turned it off, and the problem did go away - though the map of course became very hard to read.
So, instead I tried GIF output. Same problem. JPEG output works properly - but JPEG quality is pretty poor.
So, I tried PNG24. It fixes the issue. Thanks for the suggestion! It does cause "TRANSPARENT TRUE" on the SCALEBAR object to stop working correctly, but oh well...that's much easier to work around.
I still have the problem with PIXMAP symbols, if anyone has any information about that.
Thanks,
Dan
> -----Original Message-----
> From: Pericles S. Nacionales [mailto:nacional at cbs.umn.edu]
> Sent: Wednesday, October 15, 2003 12:15 PM
> To: Martin, Daniel A; Mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Upgraded 3.6 to 4.0 Windows binary and
> Do you happen to have antialiasing turned on for your labels?
> Try turning
> them off temporarily and see if the colors are rendered
> right. You might
> have to play around with the antialiasing and/or use "png24"
> to render your
> output images.
> Sorry I can't help further as I'll be out of town and away
> from my computer
> until next week.
> -Perry
> On Wednesday 15 October 2003 11:23 am, Martin, Daniel A wrote:
> > I've been using PIXMAP symbols from transparent GIF source
> images for many
> > versions now. I upgraded to the 4.0 release, using the
> compiled Windows
> > binary from the UMN website. In the process, these PIXMAP
> symbols that
> > always worked have stopped working. The symbols don't show
> in the legend,
> > and turning them on causes no map to return. Downgrading
> to 3.6 gets them
> > working again.
> > I'm also having issues with some text-labels. I have some
> yellow text
> > labels. Under 3.6 they worked fine. Under 4.0, they
> aren't always yellow.
> > Sometimes they are brown, sometimes red, depending on what
> else is on the
> > screen. However, if I turn on a yellow symbol, they become
> yellow as
> > intended. It's as if my labels can only consume a color
> already in the
> > palette. I've attached a few screenshots illustrating this issue.
> Conservation Biology Program
> University of Minnesota
> e-mail: nacional at cbs.umn.edu
> phone: (612) 624 5765
