[Mapserver-users] Mapscript drawQuery() on big PostGIS layers, oid indexes, and getResult()
Daniel Faivre daniel.faivre at camptocamp.com
Thu Oct 16 06:57:23 EDT 2003
  Great thanks to David and Paul for their good advices. As I used
"using unique", I've wrongly thought that indexing oid wasn't necessary.
With an index on oid, my problem was "half-solved": it's now possible to
use the drawQuery() on my big layer.
But there's still a problem: how could I properly retrieve fields values
for all queried features ? The problem is that if I use
$my_big_layer->getResult($idx) in a loop to get the features ids,
execution time is too long.
I see two ways to solve this last problem:
1) Adding a PostGIS query after the similar Mapserver query, and using
PostGIS results for db processes and Mapserver result only for drawing ?
2) Adding another web page just to do the same query a second time
without any other task, to break the timeout barrier ?
Which is the best idea ? Is there a third solution ?
Best regards,
Daniel Faivre
Ohceo - Camptocamp
04 79 75 28 19
180 rue du Genevois
73000 Chambéry le Haut
David Blasby wrote:
> Paul Ramsey wrote:
>>   Cost analysis. On large enough tables and complex enough queries,
>> cost analysis gets important. A PostGIS installation with the STATS
>> option enabled and stats calculated can do the "right thing" in
>> query  planning which a naive installation completely screws up.
> Whats happening is that postgresql is using the spatial index (which
> presumably returns the entire layer), then does a sequencial scan to
> find the rows with the "filter" attributes.
> The most likely problem is you dont have an index on OID:
> CREATE INDEX mybigpolygon_table_oid_idx ON mybigpolygon_table (oid);
> You might find that turning on stats will give you speed improvements.
> To do this:
> 1. make sure your postGIS makefile has "USESTATS=1" set
> 2. in postgresql, do a "SELECT UPDATE_GEOMETRY_STATS();"
> 3. in postgresql, do a "VACUUM ANALYSE"
> If this doesnt work, I'll need more information.  Turn the layer's
> DEBUG flag to on, and run your script.  You should see the SQL query
> go by (it starts with "DECLARE CURSOR mycursor FOR ...".
> If it says "DECLARE CURSOR mycursor FOR SELECT the_geom,oid FROM
> mybigpolygon_table", then go into postgresql and type:
> EXPLAIN ANALYSE SELECT the_geom,oid FROM mybigpolygon_table
> (I replaced the 'DECLARE CURSOR mycursor FOR' with 'EXPLAIN ANALYSE')
> The output will tell you what postgresql is doing and how long its
> taking.
> dave
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Daniel Faivre
Ohceo - Camptocamp
04 79 75 28 19
180 rue du Genevois
