[Mapserver-users] GRASS raster
Ling-Yen Liao
lyl209 at nyu.edu
Fri Oct 17 15:55:45 EDT 2003
Hi, I'm trying to find where the problem is.
$ /usr/local/bin/gdal-config --formats
finds grass;
$ ldd /usr/local/bin/libgdal.1.1.so
has a link to libgrass: libgrass5.so.0 => /usr/lib/libgrass5.so.0 (0x40300000);
also
$ gdalinfo soils
prints out something and looks like no problem;
but
$ /var/www/cgi-bin/shp2img -m soilsmap -o soils.png
outputs a BLANK img.
So anybody knows what's wrong?
Thank you!
-LY
----- Original Message -----
Date: Friday, October 17, 2003 3:17 am
Subject: [Mapserver-users] GRASS raster
> Hello,
> I'm trying to use Mapserver to display grass raster files.
> 1. I put .grassrc5 file under /var/www/html
> 2. Here is my map file
> NAME GRASS
> STATUS ON
> SIZE 950 700
> SYMBOLSET /var/www/html/grsmap/map-script/marker.sym
> # W S E N
> EXTENT 590000 4914000 609000 4928000
> #GRASS raster map directly from location (8bit only):
> LAYER
> NAME soils
> TYPE RASTER
> STATUS on
> data "/data/grassdata/spearfish/PERMANENT/cellhd/soils"
> END # Layer
> end
> The weird thing is, when I open my browser with
> http://localhost/cgi-bin/mapserv36?map=/var/www/html/grsmap/map-
> script/soils.map&mode=mapThe title will be mapserv36(PNG Image,
> 950x700 pixels), and no error messages (I checked
> /var/log/httpd/error_log). But! The content of the browser is
> BLANK. It looks like a white map in it...
> I really don't know what happened, can anyone tell me?
> I use redhat 9, GRASS 5.0.3, Mapserver 3.6.
> (BTW, I found that if I change the status to default then the
> result will become "Server error! Error 500" and I don't know why.)
> Best,
> LY
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
