[Mapserver-users] Using OGR with tab files
Mon Oct 20 11:48:38 EDT 2003
Phil Maskell wrote:
> Hi,
> I have set MapServer 4.0 up with the demo, I have used OGR to load a
> POLYGON type layer from a tab, but cannot get it to work with LINE or
> POINT.
> # This doesn't work
> LAYER
> 	NAME Motorways
> 	TYPE LINE
> 	STATUS DEFAULT
> 	CONNECTIONTYPE OGR
> 	CONNECTION "data/Motorways.TAB"
> 	STYLEITEM "AUTO"
> 	CLASS
> 		NAME "Motorways"
> 	END
> 	PROJECTION
> 		"AUTO"
> 	END
> END # Layer
Phil,
In what way does it not work?  You just don't see any features drawn?
I would suggest:
  o Examine the file in question with ogrinfo and ensure the feature are
    actually displayed as LINESTRINGs.  "eg. ogrinfo -ro -al data/Motorways.TAB"
  o Also verify that the bounds reported by ogrinfo make sense.
  o Try removing the STYLEITEM "AUTO" and see if you get anything with default
    coloring.  You might have to set a color in your CLASS.
Good luck,
