[Mapserver-users] Using CGI version of MapServer4.0 with layers
Phil Maskell maskellp at ntlworld.com
Tue Oct 21 03:42:22 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_009C_01C397AF.3EAEF430
Content-Type: text/plain;
	charset="Windows-1252"
Content-Transfer-Encoding: quoted-printable
Hi all,
=20
I have managed to get the CGI Version of MapServer 4 to work being
called from a servlet (impressed by the speed compared to other servers
I=92ve played with).=20
=20
All is working fine; I can zoom in/out pan etc=85 I now want to be able =
to
toggle layers on and off using &layers=3D but doing this always resets =
the
zoom level back to the initial extent in the .map file. Is this expected
behaviour, does changing the layers reload the .map, I don=92t want to
code around this if it is something I am doing wrong.
=20
Hope this makes sense.
=20
Thanks in advance.
=20
Phil Maskell
=20
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.525 / Virus Database: 322 - Release Date: 09/10/2003
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3DWindows-1252">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C397AF.3E937CF0">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:Zoom>130</w:Zoom>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:ApplyBreakingRules/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
@page Section1
	{size:595.3pt 841.9pt;
	margin:72.0pt 90.0pt 72.0pt 90.0pt;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin:0cm;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-GB link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi all,<o:p></o:p></span></font></p>
font-family:Arial'><o:p>&nbsp;</o:p></span></font></p>
font-family:Arial'>I have managed to get the CGI Version of MapServer 4 =
to work
being called from a servlet (impressed by the speed compared to other =
servers I=92ve
played with). <o:p></o:p></span></font></p>
font-family:Arial'>All is working fine; I can zoom in/out pan etc=85 I =
now
want to be able to toggle layers on and off using &amp;layers=3D but =
doing this
always resets the zoom level back to the initial extent in the .map =
file. Is
this expected behaviour, does changing the layers reload the .map, I =
don=92t
want to code around this if it is something I am doing =
wrong.<o:p></o:p></span></font></p>
font-family:Arial'>Hope this makes sense.<o:p></o:p></span></font></p>
font-family:Arial'>Thanks in advance.<o:p></o:p></span></font></p>
font-family:Arial'>Phil Maskell<o:p></o:p></span></font></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p>&nbsp;</o:p></span></font></p>
</div>
</body>
</html>
<BR>
<P><FONT SIZE=3D2>---<BR>
Outgoing mail is certified Virus Free.<BR>
Checked by AVG anti-virus system (http://www.grisoft.com).<BR>
Version: 6.0.525 / Virus Database: 322 - Release Date: 09/10/2003<BR>
</FONT> </P>
------=_NextPart_000_009C_01C397AF.3EAEF430--
