[Mapserver-users] GetFeatureInfo problem with getting GML back
Daniel Morissette morissette at dmsolutions.ca
Tue Oct 21 09:32:14 EDT 2003
bartvde at xs4all.nl wrote:
> Found the problem already, forgot DUMP TRUE in the mapfile.
> Perhaps it is an idea to write a comment in the resulting GML file?
> <!-- warning: no layers with DUMP TRUE found in mapfile -->
Well, since it is OK for someone to setup a WMS with no queryable layer
I think this warning could be misleading.  Perhaps we could produce a
warning only if a layer has a template set but doesn't have dump true:
<!-- WARNING: This layer is queryable but doesn't have DUMP TRUE so no
output will be produced for info format GML -->
BTW, this DUMP TRUE behavior is likely to change when we get to bug 300:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=300
Daniel
  DM Solutions Group              http://www.dmsolutions.ca/
