[Mapserver-users] web_map_template / mapserv4
robert fritz
robert-fritz at web.de
Wed Oct 22 09:37:37 EDT 2003
<html><base href=3D"https://freemail.web.de/"/><style>p {margin: 0px}</style=
><body style=3D'font-size:9pt; font-family:Verdana; font-family: Verdana' ><=
P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-=
ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman">Hello,<=3Fxm=
l:namespace prefix =3D o ns =3D "urn:schemas-microsoft-com:office:office" /><o=
:p></o:p></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0c=
m 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FON=
T face=3D"Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P clas=
s=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-l=
anguage: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman"> <o:p></o:p=
></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><=
SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"=
Times New Roman">I change the main map template using the url (web=5Fmap=5Ftem=
plate):</FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm =
0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT =
face=3D"Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P class=3D=
MsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-lan=
guage: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman">http://192.168.20.=
30/scripts/mapserv.exe=3Fmode=3Dbrowse&=85 &map=5Fweb=5Ftemplate=3DD%3A%5Cdemo=
%5Csub%5Cdemo%5Chtml%5Cprint.html&program=3D%2Fscripts%2Fmapserv.exe&=
;layer=3D1&<o:p></o:p></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D=
"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><F=
ONT size=3D3><FONT face=3D"Times New Roman"> <o:p></o:p></FONT></FONT></S=
PAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB st=
yle=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman">I=
t works fine on Mapserv 366 / Win2000.<o:p></o:p></FONT></FONT></SPAN=
></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=
=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman">&nbs=
p;<o:p></o:p></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0c=
m 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3>=
<FONT face=3D"Times New Roman">It does not work using the new Mapserv4 =
/ Win2000:<o:p></o:p></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MA=
RGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT=
size=3D3><FONT face=3D"Times New Roman"> <o:p></o:p></FONT></FONT></SPAN=
=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman">http=
://localhost/scripts/mapserv4.exe=3Fmode=3Dbrowse&=85 &map=5Fweb=5Ftemplate=3D=
D%3A%5Cdemo%5Csub%5Cdemo%5Chtml%5Cprint.html&program=3D%2Fscripts%2Fmaps=
erv4.exe&layer=3D1<o:p></o:p></FONT></FONT></SPAN></P><P class=3DMsoNormal=
style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN=
-GB"><FONT size=3D3><FONT face=3D"Times New Roman"> <o:p></o:p></FONT></F=
ONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DE=
N-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New R=
oman">I get the template from the map file, not the template from the url.=
<o:p></o:p></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm =
0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><F=
ONT face=3D"Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P><P cl=
ass=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi=
-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman"> <o:p></o=
:p></FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"=
><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=
=3D"Times New Roman">What's the problem=3F<o:p></o:p></FONT></FONT></SPAN></P>=
<P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso=
-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Times New Roman"> </F=
ONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"MARGIN: 0cm 0cm 0pt"><SPAN=
lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FONT size=3D3><FONT face=3D"Time=
s New Roman">Thank you,</FONT></FONT></SPAN></P><P class=3DMsoNormal style=3D"=
MARGIN: 0cm 0cm 0pt"><SPAN lang=3DEN-GB style=3D"mso-ansi-language: EN-GB"><FO=
NT size=3D3><FONT face=3D"Times New Roman">robert<o:p></o:p></FONT></FONT></SP=
AN></P></body></html>
=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=5F=
=5F=5F=5F=5F<br>Zwei Mal Platz 1 mit dem jeweils besten Testergebnis! WEB.DE FreeM=
ail<br>und WEB.DE Club bei Stiftung Warentest! <A HREF=3D"http://f.web.de/=3Fm=
c=3D021183"><B>http://f.web.de/=3Fmc=3D021183</B></A>
