[Mapserver-users] Logging user activities
Till Adams adams at terrestris.de
Wed Oct 22 10:24:50 EDT 2003
Giri,
use the "LOG" keyword in your Web-section. the logile must exist (in
this case in the same directory as the mapfile)
WEB
  LOG turin.log
  TEMPLATE xxx.html
  IMAGEPATH 'C:/usr3/htdocs/mapserver/temp/'
  IMAGEURL 'http://localhost/mapserver/temp/'
# EMPTY 'http://localhost/mapserver/turin/nothing.html'
  METADATA
Cheers,
Till
Palanisamy, Giri schrieb:
> Hi,
> I would like to log information about the user activities, is there a
> way to do this? I am using Mapserver 4 (JBOX and mapscript) on IIS
> (Windows 2000). I need to log when ever the user enters the query
> results page. Is there any documentation about logging user activities?
> Thanks
> Giri
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Jorge del
> Pozo
> Sent: Monday, October 13, 2003 10:14 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] Java mapserver HOWTO and questions
> Hello.
> I've been working with mapserver and java. I have written a JSP but when
> i try to execute them i get this error:
> java.lang.UnsatisfiedLinkError:
> /home/user/JBuilder9/jdk1.4/jre/lib/i386/libmapscript.so:
> /home/user/JBuilder9/jdk1.4/jre/lib/i386/libmapscript.so: undefined
> symbol: pj_is_latlong
> I compile the mapscript for java and also i include the libmapscript.so
> in the code of the JSP.
> I'm working with mapserver-3.6.5. Is the libmapscript.so broken?
> How can i show a map with jsp and mapscript?
> thanks.
> Umberto Nicoletti(unicoletti at prometeo.it)@26.09.2003 17:34:03 +0000:
>>Hi, me again.
>>I have written a small howto on mapserver and java and wish to
>>contribute it to the community.
>>Hope you will find it useful, but don't stop reading here!!
>>I'd like to 'exchange' this howto with some answers from the ones of
> you
>>who know the inner workings of mapserver.
>>these are the questions:
>>1) I have read about thread safety issues and I am of course
> concerned.
>>See:
> http://lists.dmsolutions.ca/pipermail/mapserver-users/2002-August/003637
> .html
>>What is the current status for this topic with regard to Java
> mapscript?
>>2) Is Java mapscript support being worked on?
>>About the thread safety issue i have made a few tests of my own.
>>I have a couple of jsp that allow one to zoom/map/query the same
> europe
>>map from php examples and I have set the isThreadSafe attribute on
> each
>>of them.
>>Then I used an automated load test tool (jmeter) to load test the
>>application. I simulated 20 users performing three zoom and two query
>>operations. Each user executed 5 times these operations for a total of
>>500 requests.
>>All were executed without errors.
>>I will probably execute other tests in the next few days, but now I DO
>>need answers with regard to the questions above (if someone has them,
> of
>>course).
>>Thanks in advance,
>>Umberto
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
***** Besuchen Sie uns auf der acqua alta *****
*****   vom 24.-27. November in München   *****
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
