[Mapserver-users] php/mapscript error
woodbri at swoodbridge.com
Thu Oct 23 09:57:20 EDT 2003
I think I used PHP 4.3.0 which is know to have a bug that messes up
$PHP_SELF variable and has a document workaround on wiki or the
archives. I also have gotten it to work with PHP 4.3.1 which is a
better choice because it fixes a security bug in PHP 4.3.0.
-Steve W.
On 23 Oct 2003 at 16:42, Murat Isik wrote:
> Thank you,
> Do you remember which php version worked with you?. I am using php-4.2.2-17.
> ----- Original Message -----
> From: <woodbri at swoodbridge.com>
> To: <mapserver-users at lists.gis.umn.edu>; "Murat Isik"
> <muratisik at megatek.com.tr>
> Sent: Thursday, October 23, 2003 4:31 PM
> Subject: Re: [Mapserver-users] php/mapscript error
> > Murat,
> > Please note the the error:
> > > Warning: Unexpected character in input: ' in /usr/bin/php on line 358
> > is not your php script but the php executable. What has happened here
> > is that PHP is getting passed the PHP executable as the script name
> > and is trying to interpret the executable as the script. I think this
> > is problem between Apache and PHP when PHP is configured as a CGI
> > module. I have run into this problem before and was able to solve it
> > by changing to different version of PHP. I didn't try to diagnose the
> > problem just found a workaround to avoid it.
> > -Steve W.
> > On 23 Oct 2003 at 16:11, Murat Isik wrote:
> > > Hello,
> > > I have been working onphp for the last couple of days with mapscript in
> order to write my own dynamic-layer-generating code. But I hit a hard rock
> along the way.
> > > I am running Redhat 9.0, apache 2.0, mapserver 3.6.0, php-4.2.2-17,
> php-mapscript-3.6.0-4. All mapserver and php related stuff is installed
> through related rpms.
> > > Php works fine both with its own info.php and mapscript's
> phpinfo_mapscript.phtml.
> > > When I test test_draw_map.phtml, I get the following error: (which I
> believe is well known)
> > > Fatal error: Due to thread-safety problems, php_mapscript cannot be used
> as a 'apache2filter' module. You will have to reconfigure your PHP as a CGI
> to run this version of MapScript. See
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI. in
> > /var/www/html/mapserver/itasca/test_draw_map.phtml on line 34
> > > I follow the link and do whats told by adding
> > > Action application/x-httpd-php /cgi-bin/php
> > > line to httpd.conf.
> > > Then I test the same test_draw_map.phtml, I get the error:
> > > Parse error: parse error, unexpected '[' in /usr/bin/php on line 358
> > > test_draw_map.phtml does not have 358 lines. Then I search this error on
> the web and end up with this bug page:
> > > http://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=73616
> > > Then I get stuck there :(
> > > Am I missing something here? This is about my ignarence on php,
> php/mapscript or is this a real problem?
> > > In any case what's the way out? I am sorry if this is stated before in
> the maillist and I missed it.
> > > Have a nice day
> > > Thank you
> > > Murat Isik
