[Mapserver-users] adding shapefiles in .map file
Stephen Clark stephen.clark at focus.ca
Thu Oct 23 18:11:16 EDT 2003
Scott,
Adding a shape file may only work if you are adding a Shape file in the
general vicinity of the sample dataset extents.
So basically check your extents in your shape file and confirm that they are
inside the extents of the demo extents in the demo.map file.
hope this helps some...
Stephen
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Thursday, October 23, 2003 1:54 PM
Subject: [Mapserver-users] adding shapefiles in .map file
> i'm experimenting with the 'demo' mapserver file and tried adding a new
> shapefile into the program.  I haven't been able to make the shapefile
> appear in the viewer.  Not sure if it's a projection problem or what... Am
I
> missing something?
> thanks
> Scott Ferguson
> GIS Manager
> Global Routing Technologies
> (636) 449-3212
> email: scottf at secr.com
> http://www.grti.net
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
