[Mapserver-users] 4.0 itemquery - layer and area of interest do not overlap
Chris Storozuk
cstorozuk at shaw.ca
Fri Oct 24 21:10:03 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_000A_01C39A6A.CFCCC420
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Using MapServer 4.0, when doing an itemquery on a record I know exists, =
I am getting the error:
msQueryByAttributes(): Search returned no results. No matching record(s) =
found, layer and area of interest do not overlap.=20
If I can say that the extents in the MAP area of my .map file are =
absolutely sufficient to cause the queried feature to fall within it, =
what else could cause this to happen? (I used Arcview's coordinates to =
make sure the extent was correct by hovering over the top-left and =
bottom-right corners of my shapefile, so I know the extents are =
correct.)
Thanks,
Chris
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2733.1800" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>
<DIV><FONT face=3DArial size=3D2>Using MapServer 4.0, when doing an =
itemquery on a=20
record I know exists, I am getting the error:</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>msQueryByAttributes(): Search returned =
no results.=20
No matching record(s) found, layer and area of interest do not overlap.=20
</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>If I can say that the extents in =
the MAP area=20
of my .map file are absolutely sufficient to cause the queried feature =
to fall=20
within it, what else could cause this to happen? (I used Arcview's=20
coordinates to make sure the extent was correct by hovering over the =
top-left=20
and bottom-right corners of my shapefile, so I know the extents are=20
correct.)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>Chris</FONT></DIV></FONT></DIV></BODY></HTML>
------=_NextPart_000_000A_01C39A6A.CFCCC420--
