[Mapserver-users] Perl Mapscript Setup errors : tricky windows problem
Lowell Filak
lfilak at medinaco.org
Tue Oct 28 14:17:47 EST 2003
I don't have direct experience with Active perl but I would expect the
usual "#!...perl -I/path_to_mapscript" to work and if it doesn't you may
need to check with Active State.
Lowell
The following message was sent by "Stephen Clark"
<stephen.clark at focus.ca> on Tue, 28 Oct 2003 09:33:07 -0800.
> Hi all,
> Thanks for the help so far.
> I have been having trouble getting Perl to accept the mapscript module.
> I believe the error is the @inc is not adding the mapscript.pm file.
> Wher would I look to add the mapscript module to the Perl list of
includes.
> My specs are:
> Win2k
> Active perl with Apache build (Perl 5.8.0)
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
