[Mapserver-users] Re: Perl Mapscript Setup errors : tricky windows problem
Stephen Clark
stephen.clark at focus.ca
Tue Oct 28 18:30:22 EST 2003
I am trying to get Perl Mapscript to work on Windows.
I was hoping someone might have some suggestions for a good set of setup
steps that will work on Win2k , Perl 5.8.0 and Apache 2..0.46
As far as the Cygwin setup :
I have installed Cygwin but cannot get any of the executables compiled under
cygwin to work with my Perl scripts. I think it is the compile parameters
set in the Makefile that are the problem.
I believe there is a set of parameters that will compile executables for DOS
or i586 or the like but I do not know at this time.
If you have some suggestions I would be willing to try them out.
thanks,
Stephen
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, October 28, 2003 1:46 PM
Subject: [Mapserver-users] Re: Perl Mapscript Setup errors : tricky windows
problem
> --- In mapserver-users at yahoogroups.com, "Stephen Clark"
> <stephen.clark at f...> wrote:
> > Hi all,
> > Thanks for the help so far.
> > I have been having trouble getting Perl to accept the mapscript module.
> > I believe the error is the @inc is not adding the mapscript.pm file.
> > Wher would I look to add the mapscript module to the Perl list of
> includes.
> > My specs are:
> > Win2k
> > Active perl with Apache build (Perl 5.8.0)
> you mean to say that you are getting Perl/Mapscript to work on
> Windows? I thought that was not really possible unless using cygwin.
> Perl/Mapscript doesn't compile on Windows, afaik.
> That said, you could anything to c:\perl\lib or c:\perl\site\lib
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
