[Mapserver-users] problem displaying raster layers; GDAL?
Emilio Mayorga
emiliom at u.washington.edu
Thu Oct 30 19:27:06 EST 2003
That was it!! Thank you, Randy! Such a simple fix, after so much
frustration. But this is great, now all the Mapserver features I wanted
to enable are working.
Cheers,
-Emilio
Randy James wrote:
> Hi
> I seem to remember that problem, i believe that i compiled
> mapserver --without-tiff and used gdals tiff lib and than
> it worked.
> Hope this helps
> Randy
> --- Emilio Mayorga <emiliom at u.washington.edu> wrote:
>>I installed Mapserver 4 a few weeks ago. Every feature I
>>enabled is
>>working great. I've loaded the Tutorial and the
>>Workshop/Itasca demo,
>>and everything is working, EXCEPT raster layers. I've
>>tried a number of
>>tests and different images, but I can't make it work.
>>I've tried output
>>imagetype png24, png, and jpeg. RGB tiffs and simple
>>1-band tiffs as the
>>raster layer. Nothing.
>>When I include and display a raster layer in my map file,
>>I get this
>>server error message: "Premature end of script headers:
>>mapserv40"
>>What's more strange is that when the file path to the
>>tiff image is
>>incorrect, Mapserver just ignores rendering that layer,
>>and does
>>everything else without an error message! That includes
>>rendering a
>>KEYIMAGE associated with that raster layer.
>>This is my MS configuration:
>>MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>SUPPORTS=PROJ
>>SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>INPUT=TIFF
>>INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL
>>INPUT=SHAPEFILE
>>And how I configured GDAL:
>>./configure --with-libz --with-png
>>--with-libtiff=internal
>>--with-geotiff=internal --with-jpeg --without-jasper
>>I am running MS on RedHat 8, with Apache 2.
>>Thanks for your help!
>>-Emilio Mayorga
