[Mapserver-users] Merge of shapefiles - works but with some problem
Palanisamy, Giri
palanisamyg at ornl.gov
Fri Oct 31 08:55:12 EST 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C39FB6.9AF9C9E8
Content-Type: text/plain;
charset="US-ASCII"
Content-Transfer-Encoding: quoted-printable
I had the same issue in my mapserver application. I didn't find any
useful tutorial for this. But I got it working by the help of the user
group.
Here is an example code: (it is all in one mapfile)
The first layer displays the 50 kilometer world maps, the if the user
zooms in it will show either 8km or 1 km depends on the zoom factor.
This works good, except some times if I pan on the 1 km or 8km image it
is drawing a strange line in between the tiles!! (this line is not
constantly created, this is very random) Is this a bug in the mapserver?
I have attached the output image with this error. Can anyone suggests
why this line is created?
LAYER
NAME MODIS50k
GROUP MODIS
TYPE RASTER
DATA ll_sds01gr50.tif
STATUS ON
MINSCALE 149000000
MAXSCALE 190000000
#MAXSCALE 10000
PROJECTION
"proj=3Dlonglat"
"ellps=3DGRS80"
"no_defs"
#"proj=3Deqc"
#"lon_0=3D-90"
#"lat_ts=3D0"
END
END
LAYER
NAME MODIS_8K
GROUP MODIS
TYPE RASTER
STATUS ON
TILEINDEX "quadsall"
TILEITEM "location"
MINSCALE 29000000
MAXSCALE 150000000
PROJECTION
"proj=3Dlonglat"
"ellps=3DGRS80"
"no_defs"
"proj=3Deqc"
#"lon_0=3D-90"
#"lat_ts=3D0"
END
END
LAYER
NAME MODIS_1K
GROUP MODIS
TYPE RASTER
STATUS ON
TILEINDEX "sections"
TILEITEM "location"
#MINSCALE 8000000
MAXSCALE 30000000
PROJECTION
"proj=3Dlonglat"
"ellps=3DGRS80"
"no_defs"
"proj=3Deqc"
#"lon_0=3D-90"
#"lat_ts=3D0"
END
END
Giri
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Johan
Antonsson
Sent: Thursday, October 30, 2003 6:44 PM
To: woodbri at swoodbridge.com; 'MapServer Users'
Subject: RE: [Mapserver-users] Merge of shapefiles
Thanks!
Does this mean I only need one mapfile for all my shape files?
Is there a good tutorial for the tiles feature?
TIA
/Johan
Johan Antonsson
johan at antonsson.com
Sent: den 30 oktober 2003 23:22
To: MapServer Users; Johan Antonsson
Subject: Re: [Mapserver-users] Merge of shapefiles
Johan,
This is exactly what tileindexes are for. So if you files are in=20
directory "data" do something like this:
find data -name "*.shp" > tile-input.txt
tile4ms tile-input.txt data-tiles
The next two lines will help with performance. I leave them up to the=20
reader to figure out :)
find data -name "*.shp" -exec shptree {} \;
shptree data-tiles
then in you mapfile
LAYER "data"
TILEINDEX "data-tiles"
And is should work! If you have a lot of different layers in "data"=20
then you will want to sort them into different tileindexes for each=20
layer.
-Steve W.
On 30 Oct 2003 at 22:45, Johan Antonsson wrote:
> Hi all,
>=20
> A couple of newbie questions that I'm having problem finding answers
to:
>=20
> I have a large set of shape files covering most of Sweden in 50 by 50
km
> squares (pieces). I would like to seamlessly generate maps within this
> dataset. Does MapServer have any support for this? I.e. to know when
its
> time to load the shape file for an adjacent map e.g. when the user
pans
> (between two squares). Or do I have to keep track of this myself?
>=20
> I have seen that MapServer has support for tiles but I haven't found
any
> good explanation what this really is. I know it's possible to generate
a
> tileindex shape file that will contain polygons for and links to a
> number of shape files but how can I make MapServer use this file? Can
it
> help me with the above problem? Can anyone point me to a good tiles
> information source?
>=20
> Thanks in advance
>=20
> /Johan
>=20
> Johan Antonsson
>=20
>=20
>=20
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>=20
Content-Type: image/gif;
name="FLUXNET10675476833276.gif"
Content-Transfer-Encoding: base64
Content-Description: FLUXNET10675476833276.gif
Content-Disposition: attachment;
filename="FLUXNET10675476833276.gif"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==
------_=_NextPart_001_01C39FB6.9AF9C9E8--
