[Mapserver-users] PHP Mpascript PBM (W2K + Apache + PHP)
Daniel Morissette
morissette at dmsolutions.ca
Fri Oct 31 12:29:12 EST 2003
Guillaume MOCCAND wrote:
> hi,
> i'm trying to install PHP mapscript on my computer :
> it's W2K advanced Server + Apache 1.3.19 + PHP 4.3.3
> when i put this line in my PHP code :
> dl("php_mapscript_40.dll");
> i get a long list of errors :
> Notice: Constant MS_TRUE already defined in d:\websites\mapserver\test.php on
> line 2
> Notice: Constant MS_FALSE already defined in d:\websites\mapserver\test.php on
> line 2
> Notice: Constant MS_ON already defined in d:\websites\mapserver\test.php on
> line 2
> ... and many more ...
It is very likely that php_mapscript is loaded twice. Make sure you
don't have two dl() calls for mapscript. Also check that you don't
already load mapscript in your php.ini with a line like:
'extension=php_mapscript_40.dll'
Finally, you can also use extension_loaded() to check if a module is
already loaded before loading it again:
if (!extension_loaded("MapScript"))
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
