[Mapserver-users] Projection conversion
nicolas.fortin at ec.gc.ca nicolas.fortin at ec.gc.ca
Fri Oct 31 13:20:10 EST 2003
Thanks for your answer,
You're right, by adding SYMBOLSET 'c:\blablabla ...' and your suggestion,
the lines are very wide. :)
Nick
-----Message d'origine-----
De : David Fawcett [mailto:David.Fawcett at state.mn.us]
Envoyé : Friday, October 31, 2003 12:11 PM
À : nicolas.fortin at ec.gc.ca; warmerdam at pobox.com
Cc : mapserver-users at lists.gis.umn.edu
Objet : Re: RE : [Mapserver-users] Projection conversion
Try
LAYER
    TYPE LINE
    CLASS
        SYMBOL 'circle'
        SIZE 8
    END
END
> 3) How can I make LINE wider or POINT bigger ?  I tried using SIZE
> without success.
I believe you need to apply a symbol.  Last I knew that was the only way to
make "fat" lines or points.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
