[Mapserver-users] pdf output
woodbri at swoodbridge.com woodbri at swoodbridge.com
Mon Sep 1 19:02:41 EDT 2003
Michael,
I think I remember running into a problem with libpdf that had to do
with the fact that I had pdf support built into PHP and into
mapserver/mapscript. In my case, the PHP used its own internal libs
and mapserver used the system libs which resulted in crashing. But I
think this was specific to php_mapscript. Currently ./configure does
not detect this and prevent you from building a bad configuration.
For details see http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=370
If this turns out to be your problem also please make a note in this
bug so we can track how big this problem is for other people.
Thanks,
  -Steve W.
> -----Original Message-----
> From: Michael Heldt [mailto:mewsick at web.de]
> Sent: Monday, September 01, 2003 3:54 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] pdf output
> Hi List,
> I was trying to create a pdf using the outputformat tag, everything's
> working fine until I try to include an annotation layer... As long as
> i use polygon, line and point layers a pdf is created. When I add the
> annotation layer Mapserver is crashing... Can I use annotation layers
> at all? Or is there something wrong in my mapfile? I'll add a rough
> sample of my mapfile below this message. Maybe you can help me find
> the problem if there is one.
> Thanks in advance
> Micha
> >>> Mapserver 4.0, W2K, Apache
> NAME PDFTest
>    IMAGETYPE pdf
>    EXTENT -439.1858 -720.1234 523.3631 180.1234
>    SIZE 1200 1050
>    STATUS ON
>    UNITS meters
>    SHAPEPATH "daten"
>    FONTSET   "d:/my/path/to/the/fonts.list"
> WEB
>    TEMPLATE templ_bplan.html
>    IMAGEPATH "d:\there\are\the\pics\"
>    IMAGEURL "/the/pics/"
>    LOG "log.txt"
> END
>  OUTPUTFORMAT
>    NAME pdf
>    MIMETYPE "application/x-pdf"
>    DRIVER pdf
>    EXTENSION "pdf"
>  END
> LAYER
>   NAME POLYLINES
>   DATA oralllin
>   STATUS DEFAULT
>   TYPE LINE
>   CLASS
>     EXPRESSION /./
>     COLOR 6 131 255
>   END
> END
> LAYER # Label
>   NAME LABELS
>   DATA oralllabels
>   STATUS DEFAULT
>   TYPE ANNOTATION
>   LABELITEM "LABEL"
>   CLASSITEM "LAYER"
>   CLASS
>     EXPRESSION ('[LAYER]' eq 'Verfahr' and '[LABEL]' ne
> 'RECHTSGRUNDLAGE' and '[LABEL]' ne 'VERFAHRENSVERMERKE:')
>     #EXPRESSION /./
>     LABEL
>       COLOR 0 0 0
>       TYPE TrueType
>       FONT Arial
>       Size 6
>       POSITION cr
>       PARTIALS TRUE
>       ANTIALIAS TRUE
>       FORCE TRUE
>     END # end of label
>   END # end of  class object
> END
> END   # end of mapfile
> ______________________________________________________________________
> __ __ Die sicherste Form der Kommunikation: E-Mails verschluesseln,
> Spam-Filter, Adressverifizierung, digitale Unterschrift:
> http://freemail.web.de <http://freemail.web.de>
> _______________________________________________ Mapserver-users
> mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
