[Mapserver-users] metadata object?
Sean Gillies
sgillies at frii.com
Sat Sep 6 12:45:08 EDT 2003
On Saturday, September 6, 2003, at 09:49 AM, Michael Schulz wrote:
> Hi,
> what would be the correct way to access the metadata of map and layer
> objects via mapscript, if you don't know the names of the metadata
> properties?
> Is there a function like getMetaData(), that doesn't take a name but
> returns a list of all metadata entries for the object?
> Just curious.
> Cheers, Michael
Hi Michael,
I've thought about this a lot. My particular need was to access the
hash
of fonts through something like
fonts = mapobj.fontset.getFonts()
fonts
['Arial','ArialHB',...]
I had this working, but then some other changes to the MapServer code
broke
my code, and then things got too hectic before the 4.0 release ... I
ended
up removing my work from the CVS.
Metadata are stored in a hashTableObj, but unfortunately there seems to
be
problems between this code and SWIG with the result that a hashTableObj
can't yet be exposed in MapScript. Ideally we want hashTableObjs with
methods like keys(), has_key(), &c.
Enter this as a feature request in the MapServer Bugzilla and I'll help
you
lobby for work on it. I think it will require a re-write of the code in
maphash.c to make it SWIG compatible or require some work on the SWIG
code
itself.
Meanwhile, I think you'll have to write some code to parse the mapfile
and
get the metadata keys.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
