[Mapserver-users] modifying a point location using
php_mapscript
Eric Bridger
eric at gomoos.org
Thu Sep 11 22:33:22 EDT 2003
You will need to create a new shapefile. AFAIK there is no way to edit/update a shape file.
You'll need to loop thru all the shapes in the shape file and add them one by one to a new file.
When you find the point you want, update the coordinates before adding it.
At 12:14 AM 09/12/2003 +0100, fx gamoy wrote:
>thanks for your answer Eric
> i have managed to get the pointobj and to use the setXY method
>but this method don't affect the location of the point in the shapefile
>$oLayertest =
>ms_newShapefileObj("f:/mapserver_data/data/mobilier/mobilier_point",-2);
>$oPoint=$oLayertest->getPoint($_SESSION["STEP"]); //where session["STEP"] is
>the index of the obj
>$oPoint->setXY($Xgeo,$Ygeo);
> $oPoint->free();
> $oLayertest->free();
>the point's location is not updated in the shape file
>any suggestion??
>thanks
>fx
>----- Original Message -----
>From: "Eric Bridger" <eric at gomoos.org>
>To: "fx gamoy" <fx.gamoy at mapxplore.com>
>Cc: "Mapserver List" <mapserver-users at lists.gis.umn.edu>
>Sent: Thursday, September 11, 2003 3:34 PM
>Subject: Re: [Mapserver-users] modifying a point location using
>php_mapscript
>> You probably need to call:
>> $lineObj = $shapeObj->line(0);
>> $pointObj = $lineObj->point(0);
>> On Thu, 2003-09-11 at 18:16, fx gamoy wrote:
>> > hello world,
>> > i am using mapserver 3.6.3 using php_mapscript
>> > i have managed to create a pointObj on a shapefile using the
>shapefileObj and the addPoint Method.
>> > Then i would like to modify the location of this pointobj.
>> > Using getfeaturebyattribute, i obtain a shapeobj corresponding to the
>pointObj i want to modify.
>> > Can i create a pointobj instead of a shapeobj in order to use the setXY
>method?
>> > or
>> > can i convert the shapeobj to a pointobj??
>> > i have seen in the doc that perl provide get,copy... methods? not in
>whith php_mapscript??
>> > thanks for all
>> > fx
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
