[Mapserver-users] Ccoordinate/projection display problem?
Ann Keane Ann.Keane at noaa.gov
Fri Sep 12 19:30:44 EDT 2003
Ed and Frank-
Thank you both.  You were correct in that I was not completly describing
the coordinates and projection.  This is all well beyond what I think I
know about cartography, so I thought the epsg code was the complete
description.  listgeo -proj4 will be invaluable to me.  We're just
getting started with the project so I've been using the full data files.
   The suggestions about reprojecting will be very helpful when we start
running the system operationally.
The resulting projection was:
PROJECTION
"+proj=laea +lat_0=45.000000000 +lon_0=-100.000000000 +x_0=0.000
+y_0=0.000 +ellps=WGS84 +units=m"
END
-Ann
Frank Warmerdam wrote:
> If you have
> listgeo handy you might try running "listgeo -proj4 shdrlfi0201.tif" to
> see what it things is a good "PROJ.4 string" representing the coordinate
> system of the file in question.
> I would guess you will want something like:
> PROJECTION
>   "+proj=laea +lat_0=45 +lon_0=-100 +datum=WGS84"
> END
> You can test convert points using the PROJ commandline tools something like
> this:
> warmerda at gdal2200[29]% cs2cs +proj=laea +lat_0=45 +lon_0=-100
> +datum=WGS84 +to +proj=latlong +datum=WGS84
>  -6086629. 4488761                                    (input)
>  156d3'31.097"E        37d45'55.65"N 0.000            (output)
