[Mapserver-users] open polygons makes mapserver crash
Eduardo Patto Kanegae eduardo at consultoria.eti.br
Fri Sep 26 09:36:34 EDT 2003
On Fri, 26 Sep 2003 09:03:22 -0400, Daniel Morissette <morissette at dmsolutions.ca> escreveu:
> De: Daniel Morissette <morissette at dmsolutions.ca>
> Data: Fri, 26 Sep 2003 09:03:22 -0400
> Para: Eduardo Patto Kanegae <eduardo at consultoria.eti.br>
> Assunto: Re: [Mapserver-users] open polygons makes mapserver crash
> Eduardo Patto Kanegae wrote:
> > # some moments after I post this message, I ran the 'shptree' against my
> > shapefile and the crashing stopped.
> Well, this is just hiding the problem and it may come back.  It would
> probably still be a good idea to submit a bug if you have a data file
> that can produce a crash (make sure you include sample mapfile and data
> in the bug).
> > # but one strange thing is that in my application(which is CGI mode) I have
> > two maps: one is main Map[map]
> > and the other is a reference map[ref], which is 1/3 of Main map dimensions.
> > The reference was drawing OK, but
> > the main map(the bigger) was crashing.
> That's because the reference map is not drawn by reading the shapefiles:
> it's just a precanned gif or png image on which MapServer draws a box.
@@ Hi Daniel,
@@ but my reference map is generated on-the-fly with a MapFile, a layer and a 'SaveImage()'
as described in my message with the subject 'MapServer CGI crash ( Is it a Bug or Bad Data ? )' that I posted today at 9:47.
thank you
> Daniel
>   Daniel Morissette               morissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
