[Mapserver-users] Problem with MapFile and PostGIS
Andrés Collao collao_andres at hotmail.com
Mon Sep 29 20:40:19 EDT 2003
now, the layer is turned ON. But they do not appear, even, i try with
polygon, line and point with de same results.
::: Andrés Collao Pérez :::
[ collao_andres at hotmail.com ]
[ andres at mapserver.cl ]
:::El hombre es un Dios cuando sueña y un mendigo cuando reflexiona.
:::Il peggior nemico del succeso è la pauta del fallimiento
:::El peor enemigo del éxito es el miedo al fracaso
----Original Message Follows----
Reply-To: vinko at cprsig.cl
To: Andrés Collao <collao_andres at hotmail.com>
CC: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Problem with MapFile and PostGIS
Date: Mon, 29 Sep 2003 20:38:38 -0400
On Mon, Sep 29, 2003 at 10:36:05PM +0000, Andrés Collao wrote:
 > I have installed Mapserver4, when reading a SHAPE is no problem, but when
 > reading and showing a LAYER whose data comes from a POSTGRES/POSTGIS
these
 > simply they do not appear...
 > These worked in version 3,6,6 of Mapserver
 > this is a mapfile code
 > LAYER
 > CONNECTIONTYPE postgis
 >    NAME "ascensores"
 >    CONNECTION "user=admin password=administrador dbname=valparaiso
 > host=localhost"
 >    STATUS OFF
the layer is turned off :-)
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
_________________________________________________________________
Charla con tus amigos en línea mediante MSN Messenger:
http://messenger.yupimsn.com/
