[Mapserver-users] Issues Installing Mapserver 4.0.1
sgay at earthsat.com sgay at earthsat.com
Thu Apr 1 12:35:51 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0024_01C417E5.DE07A890
Content-Type: multipart/alternative;
	boundary="----=_NextPart_001_0025_01C417E5.DE092F30"
------=_NextPart_001_0025_01C417E5.DE092F30
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Hello. I am looking for some help installing Mapserver on my Sun Ultra10 running Solaris 9 with SunONE Webserver 6.1 as our web
server of choice. I have compiled PHP version 4.3.4 and have downloaded all of the GNU / 3rd party software necessary to make this
work (in theory). I am also using the GNU compiler (version 3.3.2) instead of the Sun compiler. I have been compiling and
recompiling, but to no avail. I keep getting stuck on the same error, and have changed/tweaked the PHP config/install many times.
The other entries pertaining to this problem appear to be a bit dated, and do not appear to apply to my case. Is there anyone that
has had a similar experience with Sun / Solaris and can point me in the right direction? The error below is the one that is causing
me all of the headaches.
Thanks in advance,
Scott
cd mapscript/php3; /usr/local/bin/make; cd ../..
make[1]: Entering directory `/home/goshko/MAPSERVER/mapserver-4.0.1/mapscript/php3'
gcc -fPIC -O2  -Wall -DCOMPILE_DL=1 -DPHP4 -DUSE_WMS_LYR  -DUSE_WFS_SVR -DUSE_WMS_SVR     -DUSE_GDAL -DUSE_OGR    -DUSE_PROJ -DUSE_P
ROJ_API_H -DUSE_EPPL -DUSE_TIFF   -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_JPEG  -I/home/goshko/MAPSERVER/mapserve
r-4.0.1 -I/usr/local/include     -I/usr/local/include -I/usr/local/include      -I/usr/local/include   -I/home/goshko/MAPSERVER/php-
4.3.4 -I/home/goshko/MAPSERVER/php-4.3.4/dl -I/home/goshko/MAPSERVER/php-4.3.4/main -I/home/goshko/MAPSERVER/php-4.3.4/Zend -I/home/
goshko/MAPSERVER/php-4.3.4/include -I/home/goshko/MAPSERVER/php-4.3.4/TSRM  -c -o php_mapscript_util.o php_mapscript_util.c
php_mapscript_util.c: In function `_phpms_fetch_handle2':
php_mapscript_util.c:147: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_handle2':
php_mapscript_util.c:199: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_string':
php_mapscript_util.c:246: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_long':
php_mapscript_util.c:272: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_double':
php_mapscript_util.c:305: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_fetch_property_resource':
php_mapscript_util.c:331: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_set_property_string':
php_mapscript_util.c:367: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_set_property_long':
php_mapscript_util.c:396: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_set_property_double':
php_mapscript_util.c:425: warning: dereferencing type-punned pointer will break strict-aliasing rules
php_mapscript_util.c: In function `_phpms_object_init':
php_mapscript_util.c:476: error: `tsrm_ls' undeclared (first use in this function)
php_mapscript_util.c:476: error: (Each undeclared identifier is reported only once
php_mapscript_util.c:476: error: for each function it appears in.)
php_mapscript_util.c: In function `_php_extract_associative_array':
php_mapscript_util.c:511: warning: dereferencing type-punned pointer will break strict-aliasing rules
make[1]: *** [php_mapscript_util.o] Error 1
make[1]: Leaving directory `/home/goshko/MAPSERVER/mapserver-4.0.1/mapscript/php3'
Scott Gay (sgay at earthsat.com), CCNP
Unix Systems / Network Administrator
Earth Satellite Corporation
Phone: (240)833-8218
Fax:     (240)833-8201
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1276" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3D"Courier New" size=3D2><SPAN =
class=3D362082117-01042004>Hello. I am=20
looking for some help installing Mapserver on my Sun Ultra10 running =
Solaris 9=20
with SunONE Webserver 6.1 as our web server of choice. I have compiled =
PHP=20
version 4.3.4 and have downloaded all of the GNU / 3rd party software =
necessary=20
to make this work (in theory). I am also using the GNU compiler (version =
3.3.2)=20
instead of the Sun compiler. I have been compiling and recompiling, but =
to no=20
avail. I keep getting stuck on the same error, and have changed/tweaked =
the PHP=20
config/install many times. The other entries pertaining to this problem =
appear=20
to be a bit dated, and do not appear to apply to my case. Is there=20
anyone&nbsp;that&nbsp;has had a similar experience with Sun / Solaris =
and can=20
point me in the right direction? The error below is the one that is =
causing me=20
all of&nbsp;the headaches.&nbsp;</SPAN></FONT></DIV>
<DIV><FONT face=3D"Courier New" size=3D2><SPAN=20
class=3D362082117-01042004></SPAN></FONT>&nbsp;</DIV>
class=3D362082117-01042004>Thanks in=20
advance,</SPAN></FONT></DIV>
class=3D362082117-01042004>Scott&nbsp;</SPAN></FONT></DIV>
<DIV><FONT face=3D"Courier New" size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3D"Courier New" size=3D2>cd mapscript/php3; =
/usr/local/bin/make; cd=20
../..<BR>make[1]: Entering directory=20
`/home/goshko/MAPSERVER/mapserver-4.0.1/mapscript/php3'<BR>gcc -fPIC =
-O2&nbsp;=20
-Wall -DCOMPILE_DL=3D1 -DPHP4 -DUSE_WMS_LYR&nbsp; -DUSE_WFS_SVR=20
-DUSE_WMS_SVR&nbsp;&nbsp;&nbsp;&nbsp; -DUSE_GDAL =
-DUSE_OGR&nbsp;&nbsp;&nbsp;=20
-DUSE_PROJ -DUSE_PROJ_API_H -DUSE_EPPL -DUSE_TIFF&nbsp;&nbsp; =
-DUSE_GD_PNG=20
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_JPEG&nbsp;=20
-I/home/goshko/MAPSERVER/mapserver-4.0.1=20
-I/usr/local/include&nbsp;&nbsp;&nbsp;&nbsp; -I/usr/local/include=20
-I/usr/local/include&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;=20
-I/usr/local/include&nbsp;&nbsp; -I/home/goshko/MAPSERVER/php-4.3.4=20
-I/home/goshko/MAPSERVER/php-4.3.4/dl =
-I/home/goshko/MAPSERVER/php-4.3.4/main=20
-I/home/goshko/MAPSERVER/php-4.3.4/Zend=20
-I/home/goshko/MAPSERVER/php-4.3.4/include=20
-I/home/goshko/MAPSERVER/php-4.3.4/TSRM&nbsp; -c -o php_mapscript_util.o =
php_mapscript_util.c<BR>php_mapscript_util.c: In function=20
`_phpms_fetch_handle2':<BR>php_mapscript_util.c:147: warning: =
dereferencing=20
type-punned pointer will break strict-aliasing =
rules<BR>php_mapscript_util.c: In=20
function `_phpms_fetch_property_handle2':<BR>php_mapscript_util.c:199: =
warning:=20
dereferencing type-punned pointer will break strict-aliasing=20
rules<BR>php_mapscript_util.c: In function=20
`_phpms_fetch_property_string':<BR>php_mapscript_util.c:246: warning:=20
`_phpms_fetch_property_long':<BR>php_mapscript_util.c:272: warning:=20
`_phpms_fetch_property_double':<BR>php_mapscript_util.c:305: warning:=20
`_phpms_fetch_property_resource':<BR>php_mapscript_util.c:331: warning:=20
`_phpms_set_property_string':<BR>php_mapscript_util.c:367: warning:=20
`_phpms_set_property_long':<BR>php_mapscript_util.c:396: warning: =
dereferencing=20
function `_phpms_set_property_double':<BR>php_mapscript_util.c:425: =
warning:=20
`_phpms_object_init':<BR>php_mapscript_util.c:476: error: `tsrm_ls' =
undeclared=20
(first use in this function)<BR>php_mapscript_util.c:476: error: (Each=20
undeclared identifier is reported only once<BR>php_mapscript_util.c:476: =
error:=20
for each function it appears in.)<BR>php_mapscript_util.c: In function=20
`_php_extract_associative_array':<BR>php_mapscript_util.c:511: warning:=20
dereferencing type-punned pointer will break strict-aliasing =
rules<BR>make[1]:=20
*** [php_mapscript_util.o] Error 1<BR>make[1]: Leaving directory=20
`/home/goshko/MAPSERVER/mapserver-4.0.1/mapscript/php3'<BR></DIV></FONT>
<DIV class=3DSection1>
<P style=3D"MARGIN-BOTTOM: 12pt"><IMG height=3D108 hspace=3D12=20
src=3D"cid:362082117 at 01042004-05a6" width=3D111 align=3Dleft=20
v:shapes=3D"_x0000_s1026"><SPAN style=3D"mso-bidi-font-size: =
10.0pt">Scott Gay (<A=20
href=3D"outbind://15/sgay@earthsat.com"><SPAN=20
style=3D"mso-bidi-font-size: 12.0pt">sgay at earthsat.com</SPAN></A>), CCNP =
<BR>Unix=20
Systems / Network Administrator<BR><A =
href=3D"http://www.earthsat.com/">Earth=20
Satellite Corporation</A><BR>Phone: (240)833-8218 <BR>Fax:<SPAN=20
style=3D"mso-spacerun: yes">&nbsp;&nbsp;&nbsp;&nbsp; =
</SPAN>(240)833-8201<BR=20
style=3D"mso-special-character: line-break"><BR=20
style=3D"mso-special-character: line-break"></SPAN></P></DIV>
<DIV>&nbsp;</DIV></BODY></HTML>
------=_NextPart_001_0025_01C417E5.DE092F30--
Content-Type: image/gif;
	name="image002.gif"
Content-Transfer-Encoding: base64
Content-ID: <362082117 at 01042004-05a6>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------=_NextPart_000_0024_01C417E5.DE07A890--
