[Mapserver-users] Upgrade to 4.0.1 query problem
Wim Blanken PI
wim.blanken at planet.nl
Fri Apr 2 02:28:43 EST 2004
This is a multi-part message in MIME format.
--Boundary_(ID_3b5JH4LDK8Jmty0szSeYbw)
Content-type: text/plain; charset=iso-8859-1
Content-transfer-encoding: 7BIT
Hello John,
Maybe you have to set the TOLERANCE and TOLERANCEUNITS. See the mapfile documentation on the
main mapserver site for the usage.
I had the same problem and this solved it.......
Regards,
Wim Blanken
----- Original Message -----
To: mapserver-users at lists.gis.umn.edu
Sent: Friday, April 02, 2004 1:59 AM
Subject: [Mapserver-users] Upgrade to 4.0.1 query problem
I upgraded from 3.6 to 4.0.1 and can not query on lines or points just polygon objects return result from the templates. Can someone point me in the right direction... I've included a piece of my map file... for layer Ppoints... Please help
# Start of map file
NAME Pville
STATUS ON
SIZE 600 600
EXTENT 401500 5461000 410000 5466600
UNITS METERS
FONTSET "C:\Inetpub\wwwroot\Parksville\fonts\fonts.list"
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER Pville_header.html
TEMPLATE Pville.html
FOOTER Pville_footer.html
MINSCALE 1000
MAXSCALE 155000
IMAGEPATH "set in Pville_init.html"
IMAGEURL "set in Pville_init.html"
METADATA
WMS_TITLE "UMN MapServer Parksville BC"
WMS_ABSTRACT "This is the UMN MapServer application for the City of Parksville located on Vancouver Island."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/Parksville/Pville_init.html"
WMS_SRS "EPSG:26915"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.gif
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 12 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 0 0 0
UNITS METERS
INTERVALS 1
TRANSPARENT FALSE
STATUS EMBED
POSITION LR
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Rem March9,04
# Start of layer definitions
LAYER
NAME Ptest
TYPE RASTER
STATUS OFF
DATA test01.tif
PROCESSING "BANDS=1,2,3"
OFFSITE 71 74 65
END #LAYER
LAYER
NAME Pparks
TYPE POLYGON
STATUS OFF
DATA Pparks
LABELITEM "NAME"
LABELMAXSCALE 5000
CLASS
NAME Parks
COLOR 40 195 48
TEMPLATE "Parks.html"
LABEL
MINFEATURESIZE 40
MINDISTANCE 100
BUFFER 10
ANGLE AUTO
POSITION AUTO
SIZE MEDIUM
COLOR 0 0 0
END #LABEL
END #CLASS
HEADER "Parks_header.html"
FOOTER "Parks_footer.html"
END #LAYER
LAYER
NAME Pwatercourse
TYPE LINE
STATUS OFF
DATA Pwatercourse
CLASS
NAME Watercourse
COLOR 49 117 185
END #CLASS
END #LAYER
LAYER
NAME Pwatflow
TYPE POLYGON
STATUS DEFAULT
DATA Pwatflow
CLASS
NAME Pwatflow
COLOR 49 37 185
END #CLASS
END #LAYER
LAYER
NAME Ppoints
TYPE POINT
DATA Ppoints
STATUS DEFAULT
LABELITEM "NAME"
LABELMAXSCALE 2000
CLASS
NAME 'Places'
TEMPLATE "\Points.html"
STYLE
COLOR 128 255 164
SYMBOL 'circle'
SIZE 7
END #STYLE
LABEL
MINFEATURESIZE 10
MINDISTANCE 20
BUFFER 5
ANGLE AUTO
POSITION AUTO
SIZE SMALL
COLOR 128 255 164
END #LABEL
END #CLASS
HEADER "Points_header.html"
FOOTER "Points_footer.html"
END #LAYER
... and on to the end...
Content-type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=Content-Type content="text/html; charset=iso-8859-1">
<META content="MSHTML 6.00.2800.1106" name=GENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY style="MARGIN-TOP: 2px; FONT: 8pt Tahoma; MARGIN-LEFT: 2px"
bgColor=#ffffff>
<DIV><FONT face=Arial size=2>Hello John,</FONT></DIV>
<DIV><FONT face=Arial size=2></FONT> </DIV>
<DIV><FONT face=Arial size=2>Maybe you have to set the TOLERANCE and
TOLERANCEUNITS. See the mapfile documentation on the</FONT></DIV>
<DIV><FONT face=Arial size=2>main mapserver site for the usage. </FONT></DIV>
<DIV><FONT face=Arial size=2>I had the same </FONT><FONT face=Arial
size=2>problem and this solved it.......</FONT></DIV>
<DIV><FONT face=Arial size=2>Regards,</FONT></DIV>
<DIV><FONT face=Arial size=2>Wim Blanken</FONT></DIV>
<BLOCKQUOTE dir=ltr
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style="FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV
style="BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: black"><B>From:</B>
<A title=JWiley at city.parksville.bc.ca
href="mailto:JWiley at city.parksville.bc.ca">John Wiley</A> </DIV>
<DIV style="FONT: 10pt arial"><B>To:</B> <A
title=mapserver-users at lists.gis.umn.edu
href="mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.gis.umn.edu</A>
</DIV>
<DIV style="FONT: 10pt arial"><B>Sent:</B> Friday, April 02, 2004 1:59
AM</DIV>
<DIV style="FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] Upgrade to
4.0.1 query problem</DIV>
<DIV><BR></DIV>
<DIV><FONT size=2>I upgraded from 3.6 to 4.0.1 and can not query on lines or
file... for layer Ppoints... Please help</FONT></DIV>
<DIV><FONT size=2></FONT> </DIV>
<DIV>#<BR># Start of map file<BR>#<BR>NAME Pville<BR>STATUS ON<BR>SIZE 600
600<BR>EXTENT 401500 5461000 410000 5466600<BR>UNITS METERS<BR>FONTSET
"C:\Inetpub\wwwroot\Parksville\fonts\fonts.list"<BR>SHAPEPATH
"data"<BR>IMAGECOLOR 255 255 255</DIV>
<DIV> </DIV>
<DIV># you may need to change this to match your MapServer build<BR>#IMAGETYPE
PNG</DIV>
<DIV> </DIV>
<DIV>#<BR># Projection definition, consult the PROJ.4 documentation for
parameter discussion<BR>#<BR>#PROJECTION<BR># "proj=utm"<BR>#
"ellps=GRS80"<BR># "zone=15"<BR># "north"<BR>#
"no_defs"<BR>#<BR># OR: <BR>#<BR># "init=epsg:26915"<BR>#END</DIV>
<DIV> </DIV>
<DIV>#<BR># Start of web interface definition (including WMS enabling
metadata)<BR>#<BR>WEB<BR> HEADER Pville_header.html<BR> TEMPLATE
Pville.html<BR> FOOTER Pville_footer.html<BR> MINSCALE
1000<BR> MAXSCALE 155000<BR> IMAGEPATH "set in
Pville_init.html"<BR> IMAGEURL "set in Pville_init.html"<BR>
METADATA<BR> WMS_TITLE "UMN MapServer Parksville
BC"<BR> WMS_ABSTRACT "This is the UMN MapServer application
for the City of Parksville located on Vancouver Island."<BR>
WMS_ACCESSCONSTRAINTS none</DIV>
<DIV> </DIV>
<DIV> # change this value to match your
setup<BR> WMS_ONLINERESOURCE "<A
href="http://localhost/Parksville/Pville_init.html">http://localhost/Parksville/Pville_init.html</A>"</DIV>
<DIV> </DIV>
<DIV> WMS_SRS "EPSG:26915"<BR> END<BR>END</DIV>
<DIV> </DIV>
<DIV>QUERYMAP<BR> SIZE 200 200<BR> STATUS ON<BR> STYLE
HILITE<BR> COLOR 255 0 0<BR>END</DIV>
<DIV> </DIV>
<DIV>#<BR># Start of reference map<BR>#<BR>REFERENCE<BR> IMAGE
graphics/reference.gif<BR> EXTENT 401500 5461000 410000
5466600<BR> SIZE 120 120<BR> STATUS ON<BR> COLOR -1 -1
-1<BR> OUTLINECOLOR 255 0 0<BR>END</DIV>
<DIV> </DIV>
<DIV>#<BR># Start of legend<BR>#<BR>LEGEND<BR> KEYSIZE 12 12<BR>
LABEL<BR> TYPE BITMAP<BR> SIZE
MEDIUM<BR> COLOR 0 0 89<BR> END<BR> STATUS
ON<BR>END</DIV>
<DIV> </DIV>
<DIV>#<BR># Start of scalebar<BR>#<BR>SCALEBAR<BR> IMAGECOLOR 255 255
255<BR> LABEL<BR> COLOR 0 0 0<BR>
SIZE tiny <BR> END<BR> STYLE 1<BR> SIZE 80
2<BR> COLOR 0 0 0<BR> UNITS METERS<BR> INTERVALS 1<BR>
TRANSPARENT FALSE<BR> STATUS EMBED<BR> POSITION LR<BR>END</DIV>
<DIV> </DIV>
<DIV>#<BR># Start of symbol definitions (we're only using a
few)<BR>#<BR>SYMBOL<BR> NAME 'circle'<BR> TYPE ELLIPSE<BR>
POINTS 1 1 END<BR> FILLED TRUE<BR>END</DIV>
<DIV> </DIV>
<DIV># Rem March9,04<BR># Start of layer definitions<BR>#<BR>LAYER<BR>
NAME Ptest<BR> TYPE RASTER<BR> STATUS OFF<BR> DATA
test01.tif<BR> PROCESSING "BANDS=1,2,3"<BR> OFFSITE 71 74
65<BR>END #LAYER <BR> <BR>LAYER<BR> NAME
Pparks<BR> TYPE POLYGON<BR> STATUS OFF<BR>
DATA Pparks<BR> LABELITEM "NAME"<BR> LABELMAXSCALE
5000<BR> CLASS<BR> NAME
Parks<BR> COLOR 40 195 48<BR>
TEMPLATE "Parks.html"<BR>
LABEL<BR> MINFEATURESIZE
40<BR> MINDISTANCE
100<BR> BUFFER
10<BR> ANGLE
AUTO<BR> POSITION
AUTO<BR> SIZE
0 <BR>
END #LABEL <BR> END #CLASS
<BR> HEADER "Parks_header.html"<BR> FOOTER
"Parks_footer.html" <BR>END #LAYER</DIV>
<DIV> </DIV>
<DIV>LAYER<BR> NAME Pwatercourse<BR> TYPE LINE<BR> STATUS
OFF<BR> DATA Pwatercourse<BR> CLASS<BR> NAME
Watercourse<BR> COLOR 49 117 185<BR> END #CLASS
<DIV> </DIV>
<DIV><BR>LAYER<BR> NAME Pwatflow<BR> TYPE POLYGON<BR> STATUS
DEFAULT<BR> DATA Pwatflow<BR> CLASS<BR> NAME
Pwatflow<BR> COLOR 49 37 185<BR> END #CLASS
<DIV> </DIV>
<DIV><BR>LAYER<BR> NAME Ppoints<BR> TYPE POINT<BR> DATA
Ppoints<BR> STATUS DEFAULT<BR> LABELITEM "NAME"<BR>
LABELMAXSCALE 2000<BR> CLASS<BR> NAME
'Places'<BR> TEMPLATE "\Points.html"<BR>
STYLE<BR> COLOR 128 255
164<BR> SYMBOL
'circle'<BR> SIZE 7<BR> END
#STYLE<BR> LABEL<BR>
MINFEATURESIZE 10<BR> MINDISTANCE
20<BR> BUFFER
5<BR> ANGLE
AUTO<BR> POSITION
AUTO<BR> SIZE
SMALL<BR> COLOR 128 255
164<BR> END #LABEL<BR> END #CLASS<BR> HEADER
"Points_header.html"<BR> FOOTER "Points_footer.html" <BR>END
#LAYER<BR>... and on to the end...</DIV></BLOCKQUOTE></BODY></HTML>
--Boundary_(ID_3b5JH4LDK8Jmty0szSeYbw)--
