[Mapserver-users] HTML Legends as lists
Stephen Clark
stephen.clark at focus.ca
Fri Apr 2 17:28:49 EST 2004
Liz,
Here is a link to a PHP layer menuing system that I am looking at
implementing
http://phplayersmenu.sourceforge.net/
I would appear that the PHP code could used to dynamically generate the tree
menu system you want but I have not looked too deeply into in.
Stephen
----- Original Message -----
To: <stephen.clark at focus.ca>; <mapserver-users at lists.gis.umn.edu>
Sent: Friday, April 02, 2004 12:58 PM
Subject: Re: [Mapserver-users] HTML Legends as lists
> Stephen,
> That's nice and all, and looks like I want it, but from a first glance,
> doesn't look very dynamic based on the map object. I don't want to have
> to manually make a legend. It should be built from my mapfile. I
> didn't read the article in great depth, so if I missed out on this very
> thing, I'm sorry.
> Liz
> >>> "Stephen Clark" <stephen.clark at focus.ca> 04/02/04 04:52PM >>>
> Liz,
> this may not be exactly what you want but if you want a tree to display
> the
> layers that is collapsible have a look at:
> http://www.microsoft.com/mind/0799/htmltree/htmltree.asp
> Stephen
> From: "Liz Godwin" <godwinl at agr.gc.ca>
> To: <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, April 02, 2004 12:16 PM
> Subject: [Mapserver-users] HTML Legends as lists
> > Hello all!
> > I've been looking into making a collapsable legend.
> > I have groups of layers, each of which have detailed class
> > information.
> > Now.. I can make an HTML legend work just fine. It's the collapsing
> > that's tricky.
> > Currently the HTML legend works that only the code between the
> > repeating sections is used, and only certain tags are available
> within
> > repeating sections. These two things are preventing me from making
> this
> > an easy solution.
> > I'd like to be able to create a heirachical list such that my group
> > knows that it's children are it's layers with the same group, and
> the
> > layers know which classes are their own. The way to do this would be
> to
> > add <ul> tags around my layers and classes. BUT I can't.
> > An alternative (but to me merely a temp. workaround) to this would
> be
> > to give an identifier to each layer and class that of it's parent so
> > that it could be found using some javascript, but alas, my group
> info
> > isn't available to my layer in the HTML template file.
> > Oh Mapserver Gurus...please tell me this would be something simple
> to
> > implement. I think a lot of other people would be interested in
> this.
> > Lists are quickly becomming a popular display method in web pages
> > instead of tables.
> > Cheers,
> > Liz Godwin
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
