[Mapserver-users] MS wont generate maps!
Johan Duflost
jduflost at ben.vub.ac.be
Mon Apr 5 01:28:36 EDT 2004
Hi Tom,
I dont't know if it can help but mapserver on my win2k didn't generate
images correctly until I put a backslash at the end of map_web_imagepath and
map_web_imageurl parameters.
map_web_imagepath=C:\applies\Apache Group\Tomcat
4.1\webapps\biomap\tmp\&map_web_imageurl=/biomap/tmp\
Johan Duflost
Johan Duflost
Analyst Programmer
Belgian Biodiversity Information Facility (BeBIF)
Universite Libre de Bruxelles (ULB)
Boulevard du Triomphe - campus de la plaine
B-1050 Bruxelles
http://gis.bebif.be
----- Original Message -----
To: <Mapserver-users at lists.gis.umn.edu>
Sent: Monday, April 05, 2004 3:38 AM
Subject: [Mapserver-users] MS wont generate maps!
> Hi All,
> Can anyone please help I'm pulling my hair out here !!!
> I have been developing a Mapserver Application on an XP machine... And
> everything has been going great, BUT I am trying to migrate across to
> a Windows 2000 Advanced Server machine !
> Both machines are running IIS 5.0
> I have set everything up in the same directories... But no matter what I
> do I cant get MapServer to generate images? I have put a LOG reference
> in the .map file but the file is not created, or if I create it nothing
> is added to it!
> MapServer is working.... Because when I have errors in my map file or in
> the url... Errors are returned. When I submit a properly formatted
> url, the template document is return with broken links for the images
> (ref, legend,scalebar and img). These link are where the images should
> be.... But no images are created !!
> I know I'm missing something simple... I just don't know what !!
> I have tried setting IMAGEPATH and IMAGEURL in the .map file or setting
> MAP_WEB_IMAGEURL and MAP_WEB_IMAGEPATH nothing seems to works
> PLEASE HELP !!
> Many Thanks
> Tom Bartlett
> # Start of map file
> MAP
> NAME UXO
> STATUS ON
> SIZE 600 600
> EXTENT 140 -26.50 154 -40
> UNITS DD
> SHAPEPATH "C:\MapServer_Data\"
> IMAGECOLOR 255 255 255
> TEMPLATEPATTERN "UXO_Basic"
> IMAGETYPE PNG
> # Start of symbol definitions (we're only using a few)
> SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
> END
> # Start of web interface definition (including WMS enabling metadata)
> WEB
> HEADER templates/header.html
> TEMPLATE "set in /index.html"
> FOOTER templates/footer.html
> MINSCALE 1000
> MAXSCALE 10000000
> IMAGEPATH "set in /index.html"
> IMAGEURL "set in /index.html"
> LOG UXO_Mapserver
> METADATA
> WMS_TITLE "UMN MapServer Itasca Demo"
> WMS_ABSTRACT "This is a UMN MapServer application for Itasca
> County located in north central Minnesota."
> WMS_ACCESSCONSTRAINTS none
> # change this value to match your setup
> WMS_ONLINERESOURCE "http://localhost/UXO/index.html"
> WMS_SRS "EPSG:26915"
> END
> END
> # Start of reference map
> REFERENCE
> IMAGE graphics/aust_ref.png
> EXTENT 111.33 -7.87 156.12 -46.84
> SIZE 150 133
> STATUS ON
> MINBOXSIZE 5
> #MAXBOXSIZE 120
> OUTLINECOLOR 255 255 255
> MARKERSIZE 9
> MARKER 'star'
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> IMAGECOLOR 0 0 0
> LABEL
> COLOR 255 255 255
> SIZE TINY
> END
> STYLE 1
> SIZE 400 2
> COLOR 255 255 255
> UNITS KILOMETERS
> INTERVALS 5
> TRANSPARENT TRUE
> STATUS ON
> END
> QUERYMAP
> SIZE 250 250
> STYLE HILITE
> COLOR 255 255 0
> STATUS ON
> END
> # Start of layer definitions
> LAYER
> NAME GMA_BUILTUPA
> TYPE POLYGON
> STATUS OFF
> DATA GMA_1m/QLD/builtupa_qld
> MAXSCALE 10000000
> MINSCALE 250000
> CLASS
> NAME 'Built-up Area'
> STYLE
> COLOR 255 190 190
> END
> END
> TOLERANCE 3
> END # GMA_BUILTUPA
> END # Map File
> <html>
> <head>
> <title>MapServer Itasca Application</title>
> </head>
> <body bgcolor="#FFFFFF">
> <center><h2>MapServer Itasca Application</h2></center>
> <p><hr><p>
> This demonstration application will take you through various levels
> of complexity. Starting with a basic application that
> allows a user to pan/zoom and change layers we add:
> <ul>
> <li> dynamically configured scalebars
> <li> javascript-based panning
> <li> query results to a frame
> <li> and finally, a DHTML rubber-band zoom/query capabilty
> </ul>
> The base data is the old-reliable Itasca dataset that we know and
> love...
> <!-- EDIT THE FORM ACTION -->
> <form name="demo" method="GET" action="/mapserv40/mapserv.exe">
> <input type="hidden" name="layer" value="GMA_BUILTUPA">
> <input type="hidden" name="zoomsize" value=2>
> <!-- EDIT THESE HIDDEN VARIABLES -->
> <input type="hidden" name="map"
> value="C:\Inetpub\wwwroot\UXO\UXO_custom.map">
> <input type="hidden" name="program"
> value="/mapserv40/mapserv.exe">
> <input type="hidden" name="root" value="/UXO/">
> <input type="hidden" name="map_web_imagepath"
> value="C:\Inetpub\wwwroot\tmp\">
> <input type="hidden" name="map_web_imageurl" value="\UXO\tmp\">
> <input type="hidden" name="map_web_template"
> value="UXO_Basic.html">
> <input type="submit" value="Initialize"></center>
> </form>
> <p><hr><p>
> </body>
> </html>
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
