[Mapserver-users] Win CE Version
Stephen Woodbridge woodbri at swoodbridge.com
Mon Apr 5 09:32:22 EDT 2004
Dharani,
There is no support currently for vb.net. I am suggesting that you look
at SWIG or the C-API and that you build an interface for vb.net. I can't
help you much more than this suggestion as I am not familiar with the
Microsoft development environment. I am guessing that you probably want
to write a COM/DCOM wrapper to mapserver that you can access via vb.net.
It is unlikely that you can use PHP/Mapscript to do what you want
without getting very convoluted, but these might give you some examples
of how to integrate similar calls into vb.net or a COM object.
Sorry, I can't help with SWIG other than to suggest that it might be
worth looking to see it they have a mode for generating COM objects, in
which case it might be a useful tool.
There are other on this list that are much more knowledgeable about
Windows technology, SWIG, mapscript than I am. May be they will jump in
here and offer their suggestions. ;)
-Steve
Dharani Babu wrote:
> Steve
> Could you tell me
> 1) which version of mapscript( It is PHP mapscript right ?) should be
> installed
> 2) steps to get SWIG +map server APIs + vb.net working with samples if
> possible please as I am fully new to SWIG .
> with regards and thanks in advance
> dharani
>> From: Stephen Woodbridge <woodbri at swoodbridge.com>
>> To: Dharani Babu <dharanibabus at hotmail.com>
>> CC: mapserver-users at lists.gis.umn.edu,  tmitchell at lignum.com,
>> spatialguru at shaw.ca,  info at peoplegis.com
>> Subject: Re: [Mapserver-users] Win CE Version
>> Date: Sat, 03 Apr 2004 09:07:46 -0500
>> Dharani,
>> A lot of points here, but I might a suggest another way of approaching
>> this problem. Mapserver has a Swig interface definition that is used
>> to build mapscript. It might be possible to build a Swig interface to
>> VB.Net or a com object so you would then compile mapserver into a dll
>> or whatever that could be called directly from VB.NET.
>> Then you can avoid all the issues of HTML, browses, etc. You would
>> then write an application making calls to mapscript to load the
>> mapfile, and generate map images what could be returned either via a
>> tmp file or as an image object that you would then display directly to
>> the screen.
>> You would build your user interface and whole application directly in
>> the native WinCE development environment and forget about all the
>> issues of webservers, networking, HTML, browses, etc.
>> Hope this helps,
>> -Steve
>> Dharani Babu wrote:
>>> Hi all
>>>    I am venturing into trails of using map server components in a win
>>> ce based device . I invite and request all of the members to add
>>> thier points .
>>> My Aim is to develope a map server component on a handheld device of
>>> like pocket PC . The first phase is to successfully deploy the
>>> mapserver exe ( either _36 or _40) at the target device with
>>> associated dlls and libs .I hope we will be in need of map server exe
>>> version for win ce platform right ? As I am using emualtor I dont
>>> face any probs as of now with accessing the mapserver exe but the
>>> case may be different when it comes to activesync it to the real
>>> device . Third phase --
>>> There are two possibilties one is that the device being connected to
>>> net( tyler this point is to you :)) . In that case from the device
>>> the user types like http:<ip>/file.html off they go !!! but the
>>> situation is not that simple . Coz the devices wont be connected to
>>> net at all . In that case we are in need of 1) passing the hidden
>>> variables to the mapserv exe WITHOUT init html 2) retrieving the
>>> temporary images created at the /tmp folder and then have to display
>>> them without BROWSER . right ? Here is where I am confused lot ..
>>> Does the IE retreive the tmp images or the mapserver maps the images
>>> to an instance of IE ? I hope the second . So in this case how to
>>> change the default behavior of mapserver's association with brower to
>>> display the images ? Fourth ..
>>> How to get the template html work done with out html ? Thats we need
>>> to have zoom in /out /pan /query feature etc Which need to be somehow
>>> fired without the template html ... And last The mother of all doubts
>>> I have is will map server work without apache or IIS ? :)
>>> I amplanning to start coding next week onwards . Hope I would be
>>> having some tons of messages in my inbox after week end ....
>>> I hope I have opened a wide area of discussion to follow ...I hope to
>>> get invaluable suggestions from the members in all ...bye for now
>>> dharani babu
>>> NB: The possible platform for mapserver component in win ce will be
>>> VB .NETsmart project ...
>>> _________________________________________________________________
>>> Studies, career, romance. Whatever your concerns.
>>> http://www.astroyogi.com/newMSN/ We have the answers.
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
