[Mapserver-users] OGC Interoperability Add-On for ArcGIS
Swaminathan, Gayathri gayathri at ou.edu
Mon Apr 5 10:16:35 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C41B18.E6D2C3A1
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi:
Is this interoperability connector comparable to the one for Arcexplorer =
as explained in,
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplorer=20
=20
In that case, can you=20
1) getCapabilities and,
2) convert it to a php file as explained in the link above
=20
and use the URL to the php file to connect from ARCGIS.....using this =
=20
Gayathri
From: mapserver-users-admin at lists.gis.umn.edu on behalf of Berend =
Veldkamp
Sent: Mon 4/5/2004 6:06 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] OGC Interoperability Add-On for ArcGIS
Has anyone sucessfully used the OGC Interoperability Add-On for ArcGIS
yet? (http://www.esri.com/software/opengis/ogc-download.html)
ArcMap is able to retrieve a list of layers, but when I try to add
one, mapserver gives this message: "loadMap(): Web application error.
CGI variable "map" is not set." The URI I use is
http://dsc586-3/cgi-bin/mapserv?map=3D../map/test1.map& so apparantly
the "map=3D" part is cut off somewhere.
Berend
Berend Veldkamp - ARIS
http://www.aris.nl/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: text/html;
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">=0A=
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">=0A=
<HTML>=0A=
<HEAD>=0A=
=0A=
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
6.5.6944.0">=0A=
<TITLE>[Mapserver-users] OGC Interoperability Add-On for ArcGIS</TITLE>=0A=
</HEAD>=0A=
<BODY>=0A=
<DIV dir=3Dltr id=3DidOWAReplyText99026>=0A=
<DIV dir=3Dltr><FONT color=3D#000000 face=3DArial =
size=3D2>Hi:</FONT></DIV>=0A=
<DIV dir=3Dltr><FONT face=3DArial size=3D2>Is&nbsp;this interoperability =
connector =0A=
comparable to the one&nbsp;for Arcexplorer as explained in,</FONT></DIV>=0A=
<DIV dir=3Dltr><FONT face=3DArial size=3D2><A =0A=
href=3D"http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplo=
rer">http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplorer=
</A></FONT>&nbsp;</DIV>=0A=
<DIV dir=3Dltr>&nbsp;</DIV>=0A=
<DIV dir=3Dltr>In that case, can you </DIV>=0A=
<DIV dir=3Dltr>1) getCapabilities and,</DIV>=0A=
<DIV dir=3Dltr>2)&nbsp;convert it to a php file as explained in the link =0A=
above</DIV>=0A=
<DIV dir=3Dltr>and use the URL to the php file to connect from =
ARCGIS.....using =0A=
this interoperability connector</DIV>=0A=
<DIV dir=3Dltr>Gayathri</DIV></DIV>=0A=
<DIV dir=3Dltr><BR>=0A=
<HR tabIndex=3D-1>=0A=
<FONT face=3DTahoma size=3D2><B>From:</B> =
mapserver-users-admin at lists.gis.umn.edu on =0A=
behalf of Berend Veldkamp<BR><B>Sent:</B> Mon 4/5/2004 6:06 =
AM<BR><B>To:</B> =0A=
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users] =
OGC =0A=
Interoperability Add-On for ArcGIS<BR></FONT><BR></DIV>=0A=
<DIV>=0A=
<P><FONT size=3D2>Hi,<BR><BR>Has anyone sucessfully used the OGC =
Interoperability =0A=
Add-On for ArcGIS<BR>yet? (<A =0A=
href=3D"http://www.esri.com/software/opengis/ogc-download.html">http://ww=
w.esri.com/software/opengis/ogc-download.html</A>)<BR><BR>ArcMap =0A=
is able to retrieve a list of layers, but when I try to add<BR>one, =
mapserver =0A=
gives this message: "loadMap(): Web application error.<BR>CGI variable =
"map" is =0A=
not set." The URI I use is<BR><A =0A=
href=3D"http://dsc586-3/cgi-bin/mapserv?map=3D../map/test1.map&amp;">http=
://dsc586-3/cgi-bin/mapserv?map=3D../map/test1.map&amp;</A> =0A=
so apparantly<BR>the "map=3D" part is cut off =0A=
somewhere.<BR><BR>Berend<BR><BR><BR><BR><BR>--<BR>_______________________=
_____<BR><BR>Berend =0A=
Veldkamp - ARIS<BR><A =0A=
href=3D"http://www.aris.nl/">http://www.aris.nl/</A><BR>_________________=
___________<BR>_______________________________________________<BR>Mapserv=
er-users =0A=
mailing list<BR>Mapserver-users at lists.gis.umn.edu<BR><A =0A=
href=3D"http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http:/=
/lists.gis.umn.edu/mailman/listinfo/mapserver-users</A><BR></FONT></P></D=
IV>=0A=
=0A=
</BODY>=0A=
</HTML>
------_=_NextPart_001_01C41B18.E6D2C3A1--
