[Mapserver-users] OGC Interoperability Add-On for ArcGIS
Paul Ramsey pramsey at refractions.net
Mon Apr 5 10:33:08 EDT 2004
You might need to do the "script wrapper" trick, wherein a shell script
is created that sets the MAPFILE environment variable and then calls
mapserv. That way the outward facing URL is bare of parameters.  There
are also some nice tricks you can do with Apache and SetEnv directives.
On Monday, April 5, 2004, at 04:06 AM, Berend Veldkamp wrote:
> Hi,
> Has anyone sucessfully used the OGC Interoperability Add-On for ArcGIS
> yet? (http://www.esri.com/software/opengis/ogc-download.html)
> ArcMap is able to retrieve a list of layers, but when I try to add
> one, mapserver gives this message: "loadMap(): Web application error.
> CGI variable "map" is not set." The URI I use is
> http://dsc586-3/cgi-bin/mapserv?map=../map/test1.map& so apparantly
> the "map=" part is cut off somewhere.
> Berend
> ____________________________
> Berend Veldkamp - ARIS
> http://www.aris.nl/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
