[Mapserver-users] WMS requests.
Bob Basques
bob.basques at ci.stpaul.mn.us
Mon Apr 5 16:26:19 EDT 2004
Swaminathan, Gayathri wrote:
>Bob:
>Your request should be,
>"http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=/var/www/html/r
>aster/horizons_wms.map&VERSION=1.1.1&REQUEST=GetMap&layer=<layername>"
Ok, this :
http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=/var/www/html/raster/horizons_wms.map&VERSION=1.1.1&REQUEST=GetMap&layer=L5
Produced this as output:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.0">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in
the LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
Using the STATUS DEFAULT for all Layers, as well as Setting STATUS OFF
to all the other layers.
>For getting a specific layer.
>Since all your layers are tied to scale(s), you think that can be a
>problem?
>Also can you include one layer with no scale set...and see if that comes
>on?
Same results as the two above produced, which is:
</ServiceException>
Maybe I should go at this a different way, what's the minimum MAP need
to look like for a WMS layer? I'll just try one LAYER out first and get
that working.
bobb
bobb
>Lemme know
>Gayathri
