[Mapserver-users] WMS requests.
Swaminathan, Gayathri
gayathri at ou.edu
Mon Apr 5 16:34:11 EDT 2004
Mea Culpa!
Should be Layers=L5.
That should work.
Gayathri
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> Bob Basques
> Sent: Monday, April 05, 2004 3:26 PM
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] WMS requests.
> Swaminathan, Gayathri wrote:
> >Bob:
> >Your request should be,
> >"http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=/var
> /www/html/
> >r
> >aster/horizons_wms.map&VERSION=1.1.1&REQUEST=GetMap&layer=<la
> yername>"
> Ok, this :
> http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=/var/w
ww/html/raster/horizons_wms.map&VERSION=1.1.1> &REQUEST=GetMap&layer=L5
> Produced this as output:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/WMS_exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.0">
> <ServiceException code="LayerNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Invalid
> layer(s) given in
> the LAYERS parameter.
> </ServiceException>
> </ServiceExceptionReport>
> Using the STATUS DEFAULT for all Layers, as well as Setting
> STATUS OFF
> to all the other layers.
> >For getting a specific layer.
> >Since all your layers are tied to scale(s), you think that can be a
> >problem?
> >Also can you include one layer with no scale set...and see if that
> >comes on?
> Same results as the two above produced, which is:
> layer(s) given in
> </ServiceException>
> Maybe I should go at this a different way, what's the minimum
> MAP need
> to look like for a WMS layer? I'll just try one LAYER out
> first and get
> that working.
> bobb
> bobb
> >Lemme know
> >Gayathri
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
