[Mapserver-users] WMS requests.
Bob Basques
bob.basques at ci.stpaul.mn.us
Mon Apr 5 18:05:03 EDT 2004
Swaminathan, Gayathri wrote:
Somebody holler if this is not on topic for MapServer . . . .
Some more investigating, using the Java Message console in ArcExplorer:
upon hitting OK for connection to my WMS server:
GetCapabilities Request :
http://pwultra5.ci.stpaul.mn.us/cp_tiles/temp/mapserv.getCapabilities.php?SERVICENAME=pw&VERSION=1.1.1&WMTVER=1.1.1&SERVICE=WMS&REQUEST=capabilities
###### Start to WMS getCapabilities in GetWMSService class version=null
************** realVersion is = 1.1.0
************** Version is = null
I'm at a loss as to why I need to set things to 1.1.0 . . . .
Everything else is using 1.1.1 (which doesn't work either BTW), but I'm
still at a loss as to why 1.1.1 shouldn't work.
bobb
>Bob,
>I would rather do the following to get the interoperability working with
>ArcExplorer...(Am gonna list all the steps for your quick reference :)
>1) Get the Interoperability extension for ArcExplorer -Java Edition
>version 4.0.1 I think.
>2) Install that.
>3) Get Capabilities using,
>http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?map=<mappath>&VERSIO
>N=1.1.1&REQUEST=Getcapabilities
>This should pop you a XML file (does not have .xml extension but, that's
>ok)- Save that to disk
>4) Do this at the beginning of the document.
><?php
> header("Content-type:application/vnd.ogc.gml");
> <WMT_MS_Capabilities version="1.1.1" updatesequence="0">=====> (This
>line is already in your capabilities file you downloaded in step 3, you
>will have
>to change the version from 1.1.0 to 1.1.1, that is all)
>5) Save file as <something>.php under your local intranet site for
>example, could be
>http://dragonslayer.ci.stpaul.mn.us/pws.php
>6) Open up ArcExplorer->Interoperability(Menu)->Connect to WMS, type in
>the URL of the .php file, For example,
>Hit OK!
>And you should get the layers.
>HTH. Let me know if you are running into issues.
>Gayathri
>>-----Original Message-----
>>From: Bob Basques [mailto:bob.basques at ci.stpaul.mn.us]
>>Sent: Monday, April 05, 2004 4:14 PM
>>To: Swaminathan, Gayathri
>>Subject: Re: [Mapserver-users] WMS requests.
>>>No problem,
>>>On the ArcExplorer...use the hints from here...
>>>http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplorer
>>>They are helpful
>>I just read in detail, the Message console is a slick troubleshooter,
>>Any idea about what this output might mean related to
>>connecting to my
>>service?
>>http://dragonslayer.ci.stpaul.mn.us/cgi-bin/mapserv?SERVICENAM
>>version=null
>>************** realVersion is = none
>>This version is not supported
>>******** Exception for WMS:null
>>java.lang.NullPointerException
>> at com.esri.ogc.client.WMSServer.refresh(WMSServer.java:236)
>> at com.esri.ogc.client.WMSServer.<init>(WMSServer.java:67)
>> at com.esri.ogc.client.WMSServer.getLayerSource(WMSServer.java:48)
>> at com.esri.ogc.client.WMSUtil.AddWMSLayer(WMSUtil.java:306)
>> at
>>com.esri.ogc.viewer.extensions.WMSConnectionDialog.jButton_OK_
>>actionPerformed(WMSConnectionDialog.java:164)
>> at
>>com.esri.ogc.viewer.extensions.WMSConnectionDialog$1.actionPer
>>formed(WMSConnectionDialog.java:74)
>> at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
>> at
>>javax.swing.AbstractButton$ForwardActionEvents.actionPerformed
>>(Unknown
>>Source)
>> at
>>javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
>> at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
>> at
>>javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown
>>Source)
>> at java.awt.Component.processMouseEvent(Unknown Source)
>> at java.awt.Component.processEvent(Unknown Source)
>> at java.awt.Container.processEvent(Unknown Source)
>> at java.awt.Component.dispatchEventImpl(Unknown Source)
>> at java.awt.Container.dispatchEventImpl(Unknown Source)
>> at java.awt.Component.dispatchEvent(Unknown Source)
>> at
>>java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
>> at
>>java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
>> at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
>> at java.awt.Window.dispatchEventImpl(Unknown Source)
>> at java.awt.EventQueue.dispatchEvent(Unknown Source)
>> at
>>java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
>> at
>>java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
>> at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
>> at java.awt.EventDispatchThread.run(Unknown Source)
>>>Gayathri
>>>>Sent: Monday, April 05, 2004 3:45 PM
>>>>>Mea Culpa!
>>>>>Should be Layers=L5.
>>>>>That should work.
>>>>Geez, I tried every combination but that one! I eve through
>>>>the "s" on
>>>>the end a couple of times. It Worked!!
>>>>Now to figure out the interoperability extension for ArcExplorer.
>>>>Thanks (A lot!!) for the help here.
>>>>bobb
