[Mapserver-users] Working with tile indexes (gdaltindex)
Michael Schulz
mschulz at webgis.de
Wed Apr 7 02:49:31 EDT 2004
i think that when using tiled data you have to provide the path to the
tileindex-shapefile with the parameter TILEINDEX not just data. Maybe
have a glimpse a the docs, since a combination of both (tileindex +
data) behaves differently again.
Cheers, Michael
> Balkanu GIS wrote:
>>Hi all,
>>Setup: MapLab 2.1rc3, ms4w, mapserver 4.0 precompiled binary for
>>Windows, Win2000, SP4.
>>I have a number of 13MB TIFF images covering a large area of Australia.
>>At the moment they are all defined as separate layers in the map file.
>>I would like to have them all referenced in a tile index. I have
>>downloaded gdaltidex and used it to create a SHP file containing
>>refernces to the raster files, however I have not been able to
>>successfully display it.
>>The relevant portion of my mapfile is below. Can anyone suggest what I
>>should do to enable the tile display? Do I need a separate class item
>>for each member of the index?
>> LAYER
>> NAME "Tiled 250k Topographic"
>> GROUP "Raster"
>> STATUS ON
>> DATA "../../../Documents and Settings/All Users/Data/Tables
>>(MI)/Rasters/Topo_250k/topo250"
>> TYPE RASTER
>> TILEITEM "location"
>> UNITS METERS
>> SIZEUNITS PIXELS
>> MAXSCALE 600000
>> CLASS
>> END
>> END
>>END
>>Yuri Banens
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
