[Mapserver-users] Mapserver - OGR - Oracle (revisited)
bartvde at xs4all.nl bartvde at xs4all.nl
Wed Apr 7 10:45:51 EDT 2004
Hi Daniel,
thanks. This works (I should have read the WMS server HowTo more carefully
Now I have found a new problem for which I cannot find the cause.
GetFeatureInfo works when the using HTML output (no info_format specified
in URL), but when using GML output I get an empty GML. There are no
strange column names with spaces in the data, which could be a cause for
this.
Here is an example from the HTML output:
GetFeatureInfo results:
Layer 'ADRESDO'
  Feature 4:
    OGR_FID = '21'
    OBJECT = 'WETH BURGERS STEE LEUTH'
    POSTCODE = '0'
    CULTUURCOD = '00'
    CULTUUR = 'ONBEKEND'
    PERCEEL = 'LEU00C 01233G0000'
The GML retrieved on the same x and y coordinates (BTW does not make any
difference which x and y I use):
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
	 xmlns:gml="http://www.opengis.net/gml"
	 xmlns:xlink="http://www.w3.org/1999/xlink"
	 xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
</msGMLOutput>
Any ideas what is causing this? No messages in the error file.
Best regards,
Bart
> bartvde at xs4all.nl wrote:
>> But now there is the following problem that a WMS GetCapabilities
>> request
>> takes more than one minute (also resulting in a full table scan in
>> Oracle). Is there any way to prevent this, can it be read from the
>> USER_SDO_GEOM_METADATA table or the MAP file?
> You can set the "wms_extent" layer metadata in the mapfile and this
> value will be used in priority. The value is "minx miny maxx maxy" in
> the same projection as the data.
> If the wms_extent is not found then MapServer does its best to calculate
> the extents, depending on the format and its implementation in OGR that
> could be very quick, or very long as you noticed here.
>   Daniel Morissette               dmorissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
