[Mapserver-users] --with-php, Mapserver 4.0.1, and Fedora
Lindsay C. Blanton
lindsay at lcblanton.com
Wed Apr 7 15:17:51 EDT 2004
Hmmm. I might give this a shot.
One thing I noticed is the PostGIS folks have a complete RPM
distribution of MapServer 4.0.1 with all associated dependencies etc for
the Fedora Core 1. It looks to be about 15 RPMs in total.
http://www.postgis.com/rpms/fedora/1/i386/
I'm going to try to install each of these in lieu of continuing with the
compile process. I can't see anywhere on PostGIS's site any indication
that their RPM installable version of MapServer 4.0.1 was compiled with
PHP support, however I would assume that it is.
I'll keep the list advised.
Lindsay
Lindsay C. Blanton
Webmaster
http://www.radioreference.com
> -----Original Message-----
> From: Paul Dugas [mailto:Paul at DugasEnterprises.com]
> Sent: Wednesday, April 07, 2004 1:30 PM
> To: Lindsay C. Blanton
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] --with-php, Mapserver 4.0.1, and Fedora
> Lindsay C. Blanton said:
> > I downloaded the source RPM's for PHP, and pointed the
> --with-php=DIR
> > directive to the source directory where they were
> installed, however
> > the configure script is still complaining that config.h /
> php_config.h
> > is not present. I can't find these files anywhere in the latest
> > distributions of PHP 4.3.5, nor with the Redhat Sources for php.
> Tried it today with the same setup and got a bit farther but
> not all the way. I installed the php-devel RPM rather than
> the full source package and got it to configure using
> 'configure --with-php=/usr/include/php/main'. Then I
> manually modified the resulting Makefile in mapscript/php3/ changing
> PHP_SRC_DIR = /usr/include/php/main
> to
> The build went okay but I got all kinds of errors (didn't
> record them but could if needed) when I copied the SO into
> the right directory, fired up apache, and hit some of the
> examples. I'm wondering if this might be an apache 2.0 problem?
> Paul
> Paul A. Dugas <paul at dugasenterprises.com> phone: 404.932.1355
> Dugas Enterprises, LLC fax: 770.516.4841
> 1711 Indian Ridge Drive, Woodstock, GA 30189 USA
> On-site at Georgia DOT, 404.463.2860 x158, paul.dugas at dot.state.ga.us
